Insteon light bulb
it seems the 2672-222 is not available anymore, so wondering if there is a simple solution for controlling a bulb in a non-insteon controlled lamp (without using a lamp module as this is a front porch light)
thanks was just reading about those. if I install at the fixture and not at the switch, can I still use it in "latching mode" ie. sense the switch or do I need to set it a "without switch mode" since not near the actual switch?  hope that makes sense
I believe you can do either. But I've only used them for direct control in the fixture, and a keypad key initiated the on / off.
FWIW I used a togglinc for my front porch light; inside as it was easier, matched the other switch, fit in the 1950's jbox and I didn't have to deal with the outdoor fixture.
Paul
Edited by paulbates
