Honeywell EVL-4 problem
Hi,
Just writing to let you know about a problem I'm having with a Honeywell Vista 20p connected to NodeLink/ISY with an EVL-4.
When a zone is tripped, it looks like NodeLink is reporting that zone, plus the previous zone as being Open.
For example, if I open my front door, it says front door zone open. Door closed then reports that zone as closed. I open my back door next, and it reports back door and front door open, even though the front door is closed. When the back door is closed, it then reports both zones as closed. If I reopen the back door it only reports the back door as open (front door stays reported as closed, as it should). Next, if I move to another zone, for example trip a motion sensor, it reports the motion sensor and back door are open. When there's no movement, everything returns to closed. When the motion sensor is tripped again, NodeLink only reports motion sensor as open.
Happy to provide logs if they would be of help (just let me know what mode you want me to enable in logs).
Thanks for supporting this product.
Ben
Yep, please fire a debug log of it happening.  That'll let me see what's actually being sent.
Thanks for the quick reply. Here's my debug log that recreates the problem. Both doors were never opened at the same time, but NodeLink reports side and garage doors both open.  Check out time 22:16:10 for the problem. Zone 6 is faulted but it also changes zone 5's state for some reason. The only pattern I notice is the mistake tends to be in the previously faulted zone.
2018-12-16 22:15:17 - ISY NodeLink Server v0.9.21 started
2018-12-16 22:15:17 - OS: Linux raspberrypi 4.14.71-v7+ #1145 SMP Fri Sep 21 15:38:35 BST 2018 armv7l GNU/Linux
2018-12-16 22:15:17 - Mono version: 5.16.0.179 (tarball Thu Oct  4 12:22:11 UTC 2018)
2018-12-16 22:15:17 - Web config server started (http://192.168.0.122:8090)
2018-12-16 22:15:18 - ISY resolved to 192.168.0.111
2018-12-16 22:15:18 - ISY Node Server config detected (profile 1)
2018-12-16 22:15:20 - ISY Warning: Duplicate node names exist on the ISY (All Off Front Room)
2018-12-16 22:15:20 - ISY Warning: Duplicate node names exist on the ISY (Mud Room Lights)
2018-12-16 22:15:20 - ISY Warning: Duplicate node names exist on the ISY (Living Room Lights)
2018-12-16 22:15:20 - ISY Warning: Duplicate node names exist on the ISY (Hallway Lights)
2018-12-16 22:15:20 - ISY Warning: Duplicate node names exist on the ISY (Kitchen Table Lights)
2018-12-16 22:15:20 - ISY Warning: Duplicate node names exist on the ISY (Home)
2018-12-16 22:15:20 - ISY Warning: Duplicate node names exist on the ISY (Ecobee - Thermostat)
2018-12-16 22:15:21 - TCP: Data Received - 8 Bytes [hwalrm1]
2018-12-16 22:15:21 - TCP: Login:[C][L] [hwalrm1]
2018-12-16 22:15:21 - Alarm: EVL User Login - Password Sent [hwalrm1]
2018-12-16 22:15:21 - Alarm: Login:
 [hwalrm1]
2018-12-16 22:15:21 - TCP: Data Received - 4 Bytes [hwalrm1]
2018-12-16 22:15:21 - TCP: OK[C][L] [hwalrm1]
2018-12-16 22:15:21 - Alarm: EVL User Login Successful [hwalrm1]
2018-12-16 22:15:21 - Alarm: Status Request Sent [hwalrm1]
2018-12-16 22:15:21 - Alarm: Data Sent - ^02,$ [hwalrm1]
2018-12-16 22:15:21 - Alarm: OK
 [hwalrm1]
2018-12-16 22:15:21 - TCP: Data Received - 9 Bytes [hwalrm1]
2018-12-16 22:15:21 - TCP: ^02,00$[C][L] [hwalrm1]
2018-12-16 22:15:21 - TCP: Data Received - 519 Bytes [hwalrm1]
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hwalrm1]
2018-12-16 22:15:21 - Alarm: Envisalink Zone Timer Dump [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 1 (Disabled (Zone 1)) Closed [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 2 (Main floor motion (Zone 02)) Closed [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 3 (Front door (Zone 03)) Closed [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 4 (Basement motion (Zone 04)) Closed [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 5 (Side door (Zone 05)) Closed [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 6 (Garage entry (Zone 06)) Closed [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 7 (Back door (Zone 07)) Closed [hwalrm1]
2018-12-16 22:15:21 - Alarm/ISY: Zone 8 (Disabled (Zone 08)) Closed [hwalrm1]
2018-12-16 22:15:22 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:15:22 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:15:22 - Alarm: Virtual Keypad Update (01,1C08,08,00,****DISARMED****  Ready to Arm  $) [hwalrm1]
2018-12-16 22:15:32 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:15:32 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:15:42 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:15:42 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:15:52 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:15:52 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:15:58 - TCP: Data Received - 115 Bytes [hwalrm1]
2018-12-16 22:15:58 - TCP: %02,0300000000000000$[C][L]%01,10000000000000000000000000000000$[C][L]%00,01,0008,05,00,FAULT 05 SIDE   DOOR            $[C][L] [hwalrm1]
2018-12-16 22:15:58 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:15:58 - Alarm: 01 - Zone State Change [hwalrm1]
2018-12-16 22:15:58 - Alarm/ISY: Zone 5 (Side door (Zone 05)) Open [hwalrm1]
2018-12-16 22:15:58 - Alarm: Virtual Keypad Update (01,0008,05,00,FAULT 05 SIDE   DOOR            $) [hwalrm1]
2018-12-16 22:16:02 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:02 - TCP: %00,01,0008,05,00,FAULT 05 SIDE   DOOR            $[C][L] [hwalrm1]
2018-12-16 22:16:02 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:02 - TCP: %02,0100000000000000$[C][L]%00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:02 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:02 - Alarm: Virtual Keypad Update (01,1C08,08,00,****DISARMED****  Ready to Arm  $) [hwalrm1]
2018-12-16 22:16:06 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:06 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:10 - TCP: Data Received - 115 Bytes [hwalrm1]
2018-12-16 22:16:10 - TCP: %02,0300000000000000$[C][L]%01,30000000000000000000000000000000$[C][L]%00,01,0008,06,00,FAULT 06 GARAGE ENTRY           $[C][L] [hwalrm1]
2018-12-16 22:16:10 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:10 - Alarm: 01 - Zone State Change [hwalrm1]
2018-12-16 22:16:10 - Alarm/ISY: Zone 5 (Side door (Zone 05)) Open [hwalrm1]
2018-12-16 22:16:10 - Alarm/ISY: Zone 6 (Garage entry (Zone 06)) Open [hwalrm1]
2018-12-16 22:16:10 - Alarm: Virtual Keypad Update (01,0008,06,00,FAULT 06 GARAGE ENTRY           $) [hwalrm1]
2018-12-16 22:16:14 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:14 - TCP: %00,01,0008,06,00,FAULT 06 GARAGE ENTRY           $[C][L] [hwalrm1]
2018-12-16 22:16:15 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:15 - TCP: %02,0100000000000000$[C][L]%00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:15 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:15 - Alarm: Virtual Keypad Update (01,1C08,08,00,****DISARMED****  Ready to Arm  $) [hwalrm1]
2018-12-16 22:16:18 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:18 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:19 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:19 - TCP: %02,0300000000000000$[C][L]%00,01,0008,06,00,FAULT 06 GARAGE ENTRY           $[C][L] [hwalrm1]
2018-12-16 22:16:19 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:19 - Alarm: Virtual Keypad Update (01,0008,06,00,FAULT 06 GARAGE ENTRY           $) [hwalrm1]
2018-12-16 22:16:19 - Alarm/ISY: Zone 6 (Garage entry (Zone 06)) Open [hwalrm1]
2018-12-16 22:16:21 - TCP: Polling Alarm [hwalrm1]
2018-12-16 22:16:21 - TCP: Data Received - 9 Bytes [hwalrm1]
2018-12-16 22:16:21 - TCP: ^00,00$[C][L] [hwalrm1]
2018-12-16 22:16:23 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:23 - TCP: %02,0100000000000000$[C][L]%00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:23 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:23 - Alarm: Virtual Keypad Update (01,1C08,08,00,****DISARMED****  Ready to Arm  $) [hwalrm1]
2018-12-16 22:16:27 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:27 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:27 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:27 - TCP: %02,0300000000000000$[C][L]%00,01,0008,05,00,FAULT 05 SIDE   DOOR            $[C][L] [hwalrm1]
2018-12-16 22:16:27 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:27 - Alarm: Virtual Keypad Update (01,0008,05,00,FAULT 05 SIDE   DOOR            $) [hwalrm1]
2018-12-16 22:16:27 - Alarm/ISY: Zone 5 (Side door (Zone 05)) Open [hwalrm1]
2018-12-16 22:16:31 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:31 - TCP: %00,01,0008,05,00,FAULT 05 SIDE   DOOR            $[C][L] [hwalrm1]
2018-12-16 22:16:32 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:32 - TCP: %02,0100000000000000$[C][L]%00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:32 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:32 - Alarm: Virtual Keypad Update (01,1C08,08,00,****DISARMED****  Ready to Arm  $) [hwalrm1]
2018-12-16 22:16:35 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:35 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:37 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:37 - TCP: %02,0300000000000000$[C][L]%00,01,0008,05,00,FAULT 05 SIDE   DOOR            $[C][L] [hwalrm1]
2018-12-16 22:16:37 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:37 - Alarm: Virtual Keypad Update (01,0008,05,00,FAULT 05 SIDE   DOOR            $) [hwalrm1]
2018-12-16 22:16:37 - Alarm/ISY: Zone 5 (Side door (Zone 05)) Open [hwalrm1]
2018-12-16 22:16:40 - TCP: Data Received - 76 Bytes [hwalrm1]
2018-12-16 22:16:40 - TCP: %02,0100000000000000$[C][L]%00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:40 - Alarm: Partition State Change [hwalrm1]
2018-12-16 22:16:40 - Alarm: Virtual Keypad Update (01,1C08,08,00,****DISARMED****  Ready to Arm  $) [hwalrm1]
2018-12-16 22:16:44 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:44 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:16:54 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:16:54 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
2018-12-16 22:17:04 - TCP: Data Received - 53 Bytes [hwalrm1]
2018-12-16 22:17:04 - TCP: %00,01,1C08,08,00,****DISARMED****  Ready to Arm  $[C][L] [hwalrm1]
Edited by beninsteon
It's a problem with the %01 (zone update) you're getting from the EVL.
The start 30 is hex, which converts to 00110000, which is saying both zones 5 & 6 are open.
You've spiked my memory on this now.
That's the reason I added the "Partition Members" when there is more than one zone specified.  I use the "Partition Ready" with "No Zones Bypassed" to close all the zones.  This still doesn't completely work because I'd need to also disable the updating based on Zone Status (%01).
I can add this to the next version, should work.
Thanks IO guy! This is exactly what I suggested at the EVL forms but it seems to have fallen on deaf ears.
Now that I understand this behavior I've written my programs to account for it, but if you think you can improve things that would be great.
If you make this change, would it be possible to include an option to leave things as they are or use whatever algorithm you're working to decide on zone status? I ask because if the EVL people issue a firmware update that corrects this at the source, that works be preferable.
Yep, I have it as a non-default option.
Thanks! Installed 925 seems to be working after preliminary testing. I'm not finding the tick box for "Disable 01 Zone Updates" has any effect -- am I crazy? Looks to me like disable 01 zone updates is enabled and can't be turned off.
EDIT: I take this back - nodelink has to be restarted for this option to be disabled once enabled.
I don't think that's the case - should take effect immediately.
