Cannot Determine Device Type
I cannot link one of my 2466dw Togglelinc dimmer switches. I've factory reset the device, there's a repeater close by, I've linked similar switches on the same floor (and phase).
I've tried using all three methods of linking this one device and each time the PSY finds the device, but is unable to add it to the ISY. Below is the communication log.
I'd appreciate any help before I pull out the tools and attempt to replace it.
TIA.
Mon 12/24/2018 06:13:08 PM : [46 b8 e0    ] Added to list of devices to link to ISY
Mon 12/24/2018 06:13:08 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 0D 00
Mon 12/24/2018 06:13:08 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 0D 00 06                 (00)
Mon 12/24/2018 06:13:08 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 0D 02           (02)
Mon 12/24/2018 06:13:08 PM : [Std-Direct Ack] 46.B8.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 12/24/2018 06:13:08 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 10 00
Mon 12/24/2018 06:13:08 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 10 00 06          ID-REQ (00)
Mon 12/24/2018 06:13:08 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 10 00    ID-REQ (00)
Mon 12/24/2018 06:13:17 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 10 00
Mon 12/24/2018 06:13:17 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 10 00 06          ID-REQ (00)
Mon 12/24/2018 06:13:18 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 10 00    ID-REQ (00)
Mon 12/24/2018 06:13:18 PM : [Std-Direct Ack] 46.B8.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 12/24/2018 06:13:26 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 10 00
Mon 12/24/2018 06:13:26 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 10 00 06          ID-REQ (00)
Mon 12/24/2018 06:13:27 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 10 00    ID-REQ (00)
Mon 12/24/2018 06:13:27 PM : [Std-Direct Ack] 46.B8.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 12/24/2018 06:13:31 PM : [46 B8 E0 0  ] Cannot determine device type
Mon 12/24/2018 06:13:31 PM : [46 B8 E0 0  ] Failed to add device, reason 2
Mon 12/24/2018 06:13:31 PM : [46 b8 e0    ] Added to list of devices to link to ISY
Mon 12/24/2018 06:13:31 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 0D 00
Mon 12/24/2018 06:13:31 PM : [All         ] Writing 0 bytes to devices
Mon 12/24/2018 06:13:31 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 0D 00 06                 (00)
Mon 12/24/2018 06:13:31 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 0D 02           (02)
Mon 12/24/2018 06:13:31 PM : [Std-Direct Ack] 46.B8.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 12/24/2018 06:13:31 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 10 00
Mon 12/24/2018 06:13:31 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 10 00 06          ID-REQ (00)
Mon 12/24/2018 06:13:32 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 10 00    ID-REQ (00)
Mon 12/24/2018 06:13:32 PM : [Std-Direct Ack] 46.B8.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 12/24/2018 06:13:41 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 10 00
Mon 12/24/2018 06:13:41 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 10 00 06          ID-REQ (00)
Mon 12/24/2018 06:13:41 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 10 00    ID-REQ (00)
Mon 12/24/2018 06:13:41 PM : [Std-Direct Ack] 46.B8.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 12/24/2018 06:13:50 PM : [INST-TX-I1  ] 02 62 46 B8 E0 0F 10 00
Mon 12/24/2018 06:13:50 PM : [INST-ACK    ] 02 62 46.B8.E0 0F 10 00 06          ID-REQ (00)
Mon 12/24/2018 06:13:50 PM : [INST-SRX    ] 02 50 46.B8.E0 3B.96.84 2F 10 00    ID-REQ (00)
Mon 12/24/2018 06:13:50 PM : [Std-Direct Ack] 46.B8.E0-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 12/24/2018 06:13:54 PM : [46 B8 E0 0  ] Cannot determine device type
Mon 12/24/2018 06:13:54 PM : [46 B8 E0 0  ] Failed to add device, reason 2
Mon 12/24/2018 06:13:54 PM : [All         ] Writing 0 bytes to devices
@robgarrett,
ISY does not recognize this device as ID-REQ command is returning either nonsensical things or they have changed the cat/subcat without letting us know. Please request for a replacement and if you still have the same issue, please do let us know.
17 hours ago, lilyoyo1 said:
Did you try factory resetting the device?
Yup, sure did. Based on advice from this thread I'm going to replace the unit in location and try the current unit on the bench (near my ISY) to see if it's defective.
Thanks for everyone's help.
R
      37.6k
      376.4k
