UI and Firmware numbers not same
Hi guys,
I'm not sure if this is an issue but I believe in the past I've had problems due to this.
(I'm not having any issues right now)
I don't see an update button for my ISY.
Is there a different place to update the UI?
If so, a point in that direction would be greatly appreciated.
Drew
48 minutes ago, andrew77 said:
Hi guys,
Drew
The Firmware and UI should be the same version otherwise you could encounter issues.
Clear your Java cache including applications then install the ISY launcher from this link.
https://forum.universal-devices.com/topic/24381-isy-launcher/
The launcher will place a icon on your desktop,  detect your ISY firmware and automatically run the correct UI version
Edited by Techman
Hi Techman,
thanks for the fast reply.
I've done what you've suggested and it seems to be right.
But when I click the shortcut (or the start.jnlp file that downloaded) it opens up the ISY Launcher and just sits there.
I seem to have to click the UUID to then get a drop down menu and then click Admin Console.
Is this correct or should it be more streamlined like before?
(I used to click the jnlp file and the admin console opened)
Drew
7 minutes ago, andrew77 said:
Hi Techman,
Drew
You're doing it properly.  This is an improvement, as you're UI and firmware versions will always stay in sync.
24 minutes ago, andrew77 said:
Hi Techman,
Drew
Yes, this is how the ISY launcher works.
Thanks for the replies guys.
Just wanted to make sure I'm loading the GUI properly.
Drew
