Hot Water Recirculation Pump Programming – Vacation Hold, etc.
I have an Insteon Micro Switch controlling a Hot Water (HW) recirculation pump via ISY.  There are three triggering mechanisms: 1) a schedule (ie., mornings); 2) KPL in the master bath; and 3) flow switch on the cold water side of the HW heater that is attached to the Sense #1 (yellow) wire of the Micro Switch.  All is working well, however;
I would like to add two additional features to increase efficiency.
1)    A vacation hold of the schedule.  Essentially, this program would suspend the scheduled run of the recirculation pump when there is no demand (no trigger of the flow switch) during defined hours of the day for 48 hours.
2) A run of the pump for 10 minutes every 72 hours when there has been no demand (no trigger of the flow switch) to prevent buildup of deposits in the water line.
I attempted to use “Last Run” of my Demand program to change a variable that is checked by the Schedule program, but that didn’t work.  I also tried using a Wait XX hours, then change variable in a control program; however, that didn’t work either because the If statement is false outside the defined hours described in A) above, and, as a result the Wait would be terminated.
Any help anyone can give me would be appreciated.  Below are the two main programs:
HW Schedule
             On Mon, Tue, Wed, Thu, Fri
             From     6:00:00AM
             To       8:00:00AM (same day)
          Or On Sat, Sun
             From     8:00:00AM
             To      10:00:00AM (same day)
    And $sHot_Water_Demand is 1
        Repeat Every  10 minutes
           Set 'Hot Water Micro' On
           Wait  5 minutes
           Set 'Hot Water Micro' Off
HW Demand
             From     8:00:05AM
             To       5:59:55AM (next day)
          Or On Fri
             From     8:00:05AM
             To       7:59:58AM (next day)
          Or On Sat
             From    10:00:05AM
          Or On Sun
             From    10:00:05AM
    And Status  'Hot Water Micro' is On
    And Status  'Hot Water Micro' is not Off
        $sHot_Water_Demand  = 1
        Wait  45 seconds
Mike
Edited by MikeF
I would use a State variable to control the pump. A simple final program to turn it on and off would be required and this may simplify the look of your programs making it easier to implement complex logic. Another advantage of a variable control is that it can only be turned on once and multiple programs can't keep hitting on it to cancel other timers.
      $sPump = $cTRUE
    set pump On
   set pump Off
Now using a vacation variable, things can be based on that logic flag
    $sVacation is $cTRUE
    Repeat every 72 hours
        $sPump = $cTRUE
        Wait 10 minutes
        $sPump = $cFALSE
    $sPump = $cFALSE   <----- vacation might be over while pump is on and then  stays on
Now you require programs to turn on your vacation mode flag. This flag will be used for many HVAC and other programs . This can be set off HVAC stats and other sources, even manually. I base mine on multiple logics. Mostly 12 MSes with different timeouts from each after seeing motion.
     $sVacation is $cFALSE   <----- add this to each existing program logic.
   AND
     your other time logic similar to what you have shown above etc..
    $sPump = $cTRUE
    $sPump = $cFALSE
To create a cycler after no action something like this could work.
   AND
   $sPump = $cFALSE
    Wait 72 hours
    $sPump = $cTRUE
    Wait 10 minutes
    $sPump = $cFALSE
    $sPump = $cFALSE  <--- another just-in-case recovery
Now you can add all your shown logic, above, to operate the $sPump variable.
This may make it easier for understanding and make program logic shorter, breaking it down into smaller logical blocks. I don't like basing program logic on other programs. I find  that method obscure and can bite you down the road because it isn't visible inside programs being edited, that another depends on it's state.
larryllix,
Thank  you for your prompt response.
Apologies for my denseness...can you go into more detail as to how I might set the 48 hour vacation flag especially as it relates to interacting with the Schedule and Demand programs?  Essentially, I would like to set the flag after 48 hours of pump inactivity during specific hours of the day and these hours are not all contiguous (ie., when we are gone, a pet sitter will come to the house in the morning and use kitchen faucet which defaults to hot water and I don't want this activity - or demand - to restart the Schedule program.  Also, it would have to ignore the pump activity generated by the Schedule program).  I think I have it started correctly, but not sure how to proceed and still be able to have the pump run as it does when we are home:
HW Schedule Ctrl
             From    10:00:05AM
             To       5:48:55AM (next day)
          Or On Fri
             From    10:00:05AM
             To       5:48:58AM (next day)
          Or On Sat
             From    10:11:05AM
          Or On Sun
             From    10:11:05AM
    And $sPump = $cFALSE
        Wait 48 hours
    Set $sVacation = $cTRUE    <--------- Not sure this would ever set because of the non-contiguous hours
   - No Actions -
(This program stops "HW Schedule" program from running when there is no demand ("HW Demand") for water for over 48 hours (ie., no one is home).  The schedule in this program reflects hours outside expected water usage by pet sitter.)
Thanks for helping me learn.
Mike
Edited by MikeF
I think you're right, $sVacation won't ever become TRUE because the WAIT 48 hours will be interrupted whenever the time is not in one of the four periods you've specified.  I think you could, however, use that program to accumulated time of non-demand and then use another program to set $sVacation to TRUE.  Something like:
No Hot Water Demand Count
             From    10:00:05AM
          Or On Fri
             From    10:00:05AM
          Or On Sat
             From    10:11:05AM
          Or On Sun
             From    10:11:05AM
        Repeat Every 1 minute
             $sNonDemandCount += 1
   - No Actions -
HW Schedule Ctrl
        $sNonDemandCount >= 2880
   - No Actions -
Now the only other thing you would need to do is to reset $sNonDemandCount to 0 whenever something you consider to be non-Pet Sitter caused demand occurs.  You could also use $sNonDemandCount for your 72 hour recirculation program.
I chose one minute intervals because the count accumulation is going to be interrupted whenever the time period shifts outside the four periods you defined.  If an hour interval were used, then you'd miss some time from 5AM (next day) to 5:48AM (next day) when the REPEAT was interrupted.
Edited by kclenden
Corrected WAIT to REPEAT
Kclenden,
Thank you for responding….and you did it!  I had actually thought about a count variable before the first post, but didn’t know how to go about it.  There may be cleaner ways to do what I’ve done (with your help and the help of larryllix), but I believe the following will work to set the sVacation flag and repeat a 10 min. run of the pump every 72 hours:
•    First, I established an hour count:
Hour Count
        From    12:00:00AM
        To      11:59:59PM (same day)
        Repeat Every  1 hour
           $sHW_NonDemand_Count += 1
   - No Actions
•    Next, I set the sVacation flag when the count is >= 48 hours and clear it with the Else statement outside of that criteria:
HW Schedule Ctrl
        $sHW_NonDemand_Count >= 48
        $sVacation  = $cTRUE
        $sVacation  = $cFALSE
•    Then, I reset the hour count variable (sHW_NonDemand_Count) when there is pump activity during the time I specify (ie., outside the hours of the Schedule program and when the pet sitter is at the house):
HW No Demand Hr Count Reset
             From    10:00:05AM
          Or On Fri
             From    10:00:05AM
          Or On Sat
             From    10:11:05AM
          Or On Sun
             From    10:11:05AM
    And $sPump is $cTRUE
        $sHW_NonDemand_Count  = 0
   - No Actions
•    Now, the Schedule program checks the sVacation variable before running:
HW Schedule
             From     6:00:00AM
          Or On Sat, Sun
             From     8:00:00AM
    And $sVacation is $cFALSE
           $sPump  = $cTRUE
           Wait  5 minutes
           $sPump  = $cFALSE
   - No Actions
For the 72 hour 10 min. pump run, I had to use a slightly different method because I did not want the pump to run inside hours that would reset the $sHW_NonDemand_Count variable.
•    As you suggested, I started by having a program evaluate the sVacation variable, then based on that evaluation set another variable:
HW 72 hr Ctrl
        $sVacation is $cTRUE        (is set to TRUE >= 48)
        Wait  24 hours
        $sHot_Water_Demand  = 3
   - No Actions
•    Once the sHot_Water_Demand variable is set to 3, the following is initiated:
HW 72 hr Vac Run
        $sHot_Water_Demand is 3
    And From     8:05:00AM
        To       8:30:10AM (same day)
        $sPump  = $cTRUE
        Wait  10 minutes
        $sPump  = $cFALSE
        $sHot_Water_Demand  = 4
   - No Actions
•    Then, a program to repeat only every 72 hours.  I realized if I included a Wait 72 hours, it would run the then statement every day at 0805 hrs, and subsequently reset the Wait.  Here is the program to repeat:
HW 72 hr Vac Run Repeat
        $sHot_Water_Demand is 4
        Repeat Every  72 hours
           Run Program 'HW 72 hr Vac Run' (Then Path)
   - No Actions
•    The sHot_Water_Demand variable is reset by:
HW Demand
             From     8:00:05AM
          Or On Fri
             From     8:00:05AM
          Or On Sat
             From    10:00:05AM
          Or On Sun
             From    10:00:05AM
        Wait  45 seconds
        $sPump  = $cFALSE
   - No Actions
Again, a heap of thanks to you both.
Mike
