February 4, 20197 yr My Makerspace is looking for relatively inexpensive on/off modules with status reporting (e.g. current watts). The $35 DMOF1 "Dome Home Automation On/Off Plug-in Switch with Energy Monitoring, Z-Wave Range Extender" caught their eye. I prefer the Aeotec "Smart Switch 6" with the LED ring, but at $50, it's tough on their tight budget. Any other <$49 smart on/off modules worth considering?
February 4, 20197 yr I have the DMOF1 but i have not included it into ISY yet. If you're looking for feedback on function I'll have to do that. For other options Zooz has good devices. What are the requirements you're looking for? Update: I pulled th DMOF1 out of a box of stuff and included it with the ISY with no issues. Everything works as it should/expected with energy reporting. Not bad little plugs. I have a bunch of the ZEN15 plugs that provide energy reporting and they work well with the ISY. I use these because they can handle heavy loads. Edited February 4, 20197 yr by simplextech
February 4, 20197 yr Look on Amazon for Neo z-wave on-off switch. They also go by Haozee and Zooz used to carry them. I have them all through the house, they show current voltage, current power, current current (heh) and total power in kWh. They automagically include, no button pushing, just set the ISY to include and plug it in. I love ‘em.ChuckSent from my iPad using Tapatalk
February 4, 20197 yr Author With the Aeotec, I use the wattage reporting in programs, can you see if "Status" for Watts works in the Dome or Neo? ZW13 - [ID 00AA][Parent 000F] If Status 'ZW 013 On-Off Power Switch' = On And Status 'ZW 013 Energy Meter' Watts (Current Power) Then - No Actions - (To add one, press 'Action') Edited February 4, 20197 yr by KeviNH
February 4, 20197 yr 10 hours ago, simplextech said: have the DMOF1 but i have not included it into ISY yet. If you're looking for feedback on function I'll have to do that. For other options Zooz has good devices. What are the requirements you're looking for? The Zooz devices you mention look interesting. I have been wanting to monitor power on my sump pumps to keep an eye on them. Maybe it's time to add Z-Wave to my ISY. Paul
February 4, 20197 yr 9 hours ago, KeviNH said: With the Aeotec, I use the wattage reporting in programs, can you see if "Status" for Watts works in the Dome or Neo? ZW13 - [ID 00AA][Parent 000F] If Status 'ZW 013 On-Off Power Switch' = On And Status 'ZW 013 Energy Meter' Watts (Current Power) Then - No Actions - (To add one, press 'Action') Is the power reporting native to the Z-Wave device or is there a node server involved? Sorry, no experience with Z-Wave. Paul
February 4, 20197 yr Author 1 hour ago, palayman said: Is the power reporting native to the Z-Wave device or is there a node server involved? Sorry, no experience with Z-Wave. I don't yet have a node server, I'm still on 4.7 at home. Reporting and conditions are all native, automatically appeared when I included the Aeotec to the ISY. Seems to be updated every minute, I think there is a configuration value on the Z-wave device to change reporting frequency.
February 4, 20197 yr 3 hours ago, palayman said: Is the power reporting native to the Z-Wave device or is there a node server involved? Sorry, no experience with Z-Wave. Z-wave energy reporting is native to the device (if energy reporting is supported by the device).
February 4, 20197 yr 8 minutes ago, simplextech said: Z-wave energy reporting is native to the device (if energy reporting is supported by the device). So is it safe to assume the Zooz device would also report like the Aeotec?
February 4, 20197 yr 34 minutes ago, palayman said: So is it safe to assume the Zooz device would also report like the Aeotec? Here's a screenshot for the Zooz ZEN15 power plug energy reporting: Reporting is configurable via Z-Wave parameters for how often it reports based on time or value thresholds.
February 4, 20197 yr 1 hour ago, simplextech said: Here's a screenshot for the Zooz ZEN15 power plug energy reporting: Reporting is configurable via Z-Wave parameters for how often it reports based on time or value thresholds. That looks great! Thanks so much. Just Ordered a couple along with the ZWave Plus dongle for my ISY.
July 18, 20196 yr I purchased some of these HAOZEEs from Amazon for $30https://amzn.to/2NYKxCr They are pretty cool in regards to power management, however, they don't seem to report whether they are on or off. I haven't had much time to play around with them yet. Here are a couple screenshots.
July 18, 20196 yr @robin71 I have that Dome plug and I've noticed that the ISY AC is what doesn't update sometimes when z-wave devices change. It's not an all the time but I did notice it a few times while testing out and adding z-wave devices.
July 19, 20196 yr Anyone know of a 240v energy monitoring plug. Does ISy allow you use wattage to triggger items, such as IF wattage greater than XX, THEN THIS, might be able to use for triggering devices when Oven or Dryer are on or off, and to tell when Dryer is done by wattage use. Never thought of using these for triggering other items before, thanks for the ideas!!!
July 19, 20196 yr @TomL, ISY definitely allows you to use wattage in programs. We use RCS PCM40 for our CEC project and they are quite reliable. We have a few left. If you want one, please send an email to sales@universal-devices.com. With kind regards, Michel
July 19, 20196 yr 19 hours ago, simplextech said: @robin71 I have that Dome plug and I've noticed that the ISY AC is what doesn't update sometimes when z-wave devices change. It's not an all the time but I did notice it a few times while testing out and adding z-wave devices. You are correct, thank you. Everything seems to be working fine now.
