February 23, 20197 yr I have been searching and cannot seem to find the correct way to configure the Homseer WD100+. I have tried numerous things but all have failed. This is what I would like to do. Right now when I press on, the light fades up very slowly and when off fades very slowly down. I would like this to change to fade quicker. I do not know where to find this in the ISY (i'm new to Zwave). Also I wanted to have double tap turn it on 50%. Cant seem to find a way to even configure double and triple tap. I.m using 5.0.13D Edited February 23, 20197 yr by hum099
February 23, 20197 yr I don't have this same switch (and I'm using 5.0.14), but according to the User Manual, you should be able to set some parameters to adjust the ramp rate. You can do that on your ISY by right-clicking on the switch in the device tree, and using the context menu: Z-Wave | Set Configuration Parameter and setting the various configuration options as described in the manual. That said, I set the configuration parameters on my switch (WD200+) using programs, such as this one (which turns the 7 LEDs on my switch to blue): DoorBlinkAllBlue - [ID 00ED][Parent 00DB][Not Enabled] If $s.SwitchLEDBlink is 0 Then Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 13 = 1 Wait 3 seconds Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 21 = 3 Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 22 = 3 Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 23 = 3 Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 24 = 3 Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 25 = 3 Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 26 = 3 Set 'Devices / dirOffice / Office Dimmer Switch' Set Configuration Parameter 27 = 3 Else - No Actions - (To add one, press 'Action') Additionally, you should be able to adjust the Fast On value in a program as well: TestSwitch - [ID 0101][Parent 00A7] If 'Devices / dirOffice / Office Dimmer Switch / ZW 014 Scene Button 1' is switched Fast On Then Set 'Devices / dirOffice / Office Dimmer Switch' 50% in 1 seconds Else - No Actions - (To add one, press 'Action') I don't have a WD100+ to test against, so approach this with appropriate skepticism.
February 27, 20197 yr Author I'm still having issues. Right now I would just like to get one thing working. When I shut off the switch I want it to ramp down faster than it is. If not possible I would like it to fast off. Sorry but I'm very new to zwave. (sorta wished I had purchased insteon switches)
