change or add module to mini light switch to work with isy994 Insteon
Due to space constraint electrician installed the 2 switches depicted in attached photo.
Is anyone aware of another solution to remote control these using an Insteon compatible remote button? I could use 2 of Insteon's toggle remotes, or one of their scene mini remotes elsewhere in the space, but I need to insert something into these switches which control 2 sets of on/off lights, both with multiple fixtures inline.
2 Insteon micro modules won't fit inside box.
Thank You @paulbates that is clearly the logical solution I was not seeing ;)
Yes I believe I'll have room in the boxes in the ceilings that the fixtures hang from. Thanks again
If all the fixtures are wired together you can you put the inline module in the first box fed from the switch.
