DSC 4020 Maxsys Integration
Has anyone done an integration with the DSC 4020?  Unfortunately Envisalink does not support this product line.  Although the alarm is "old", it's perfectly functional...except as far I can tell the HA options for it suck.  Replacing the alarm isn't really an option as even if I could re-use all the rest of the equipment the cost to replace my system boards & wall panels alone is ~$2000.  I can't justify $2k just to get HA integration if something like the PC4401 ($100) could be integrated via polyglot.
I looked at the integration documents from DSC & it's more straightforward than just about any integration option I've seen any time recently (no handshaking, no headers, only 2 - 4 params per msg).  What I'm what I'm really looking for is to get the info FROM the alarm system.  I've got around 20 motion detectors & enough keyfobs for my immediate family+.  I'd be ashamed to duplicate those with separate motion & presence detectors, especially since the DSC detectors are hardwired and already installed in the best locations.  Not to mention I'd be back in to a price range that would then send me looking at just replacing the system.
I rambled a bit above in case anyone has other suggestions outside of the PC4401/polyglot that would meet my needs.
thanks!
If your board is v3.2 or greater you can use a PC4401.  It's command set isn't that different than an IT-100 or EVL so NodeLink or Poly could easily be tweaked to support it.
It'd be the sticker on the board.  I don't think they allow for firmware updates.
V3.35.   Woohoo! I’ll have to check out pricing on the 4401 and then just figure out when I’ll have time to modify a node server...
