Sudden Problems (lots of questions)
Hello everyone! I have been gone for a long time due to a very reliable setup, but I'm back with some major (to me anyway) trouble. I hope you all can help.
My system had been running great but I had 2 SL dimmers and 3 SL relays quit working, totally blacked out with no power. So I got some replacements and installed 1 of them (a relay).
I logged in to the admin console and was advised to upgrade to the latest firmware, so I did. I performed a backup as well but the file shows that it is 0kb so I don't think there is anything in that file. I tried to restore from the backup during all this and it failed as well).
Now nothing works from the admin console. I can't even change the status of a light. I tried to do a "replace with" fuction for the new SL but I just got the eternal system busy indicator. No matter what I try I get "failed" and/or "can't communicate with device" (any of the devices even when just trying to cycle a light on and off from the admin console).
I power cycled the ISY-26 and the PLM but nothing has changed.
If I have to reset all of my devices and clear my PLM/ISY I'm ok with that as I'm going to make a bunch of changes to my current setup anyway. I have 5 replacement switches and I'm adding a couple more as well as changing a few of my scenes.
Does anyone have any suggestions I can try when I get home from work?
If I have to start from scratch, what's the best way to proceed clearing everything?
By the way here is a list of devices I have:
Universal Devices ISY-26
7 of the 8 button KPL dimmers (2486D)
11 of the Switch Link Dimmers (2476D). Will soon be 8 instead of 11.
3 of the Switch Link Relays (2476S). Will soon be 6 instead of 3.
1 Switch Link Dimmer 1000 watt (2476DH)
1 set of the old access point/phase couplers (whatever the were called)
1 OutletLink I plan to install this weekend.
1 X10 Powerflash Interface
1 X10 phase coupler that plugs in to a 220 volt drier outlet
I have about 10 scenes in the ISY.
Thanks for reading such a long post and for any input,
Wayne
If you cannot control any devices, please start by:
- close all browser windows
- clear your Java cache
http://www.universal-devices.com/mwiki/ ... Java_Cache
- open the Admin Console
- click TOOLS, DIAGNOSTICS, PLM INFO/STATUS
... and let us know what you see.
To answer your question, if you do decide to do a fresh start I personally would factory reset all your devices individually, factory reset your PLM, factory reset your ISY, and add your devices in from scratch.
I would, however, not start from scratch unless absolutely necessary. I don't believe the symptoms you are describing so far warrant it.
Mike,
Here is what I saw:
"0.0.0.V0 not connected"
I rebooted my ISY and power cycled my PLM but still get "0.0.0.V0 not connected".
Wayne
Hi Wayne,
Sounds like your PLM has gone south.
#1 Try a different Cat5 cable between the PLM and ISY
#2 Factory reset the PLM
#3 Ask SH for a replacement
Rand
Hi Wayne,
Rand
Rand
Is it possible the PLM could have been dead for a while and I just didn't know it? I have not used the admin console to operate any devices in months? I only went to use it a couple days ago so that I could replace some bad devices. Other than that it has been a case of "set it and forget it".
Seems odd/coincidental, that everything was working fine until I uprgaded the ISY firmware, but I guess its possible the PLM was already dead.
Thanks for the suggestions, I'll give them a shot after work.
Wayne
With the PLM plugged into the wall, do you see a light on it?
If so do you see any flashing on it if you were to go to a scene button on a keypad and push the button. It would have to be something that is linked to something else in order to see the flashing.
Steve L
Smarthome
If the PLM is dead, you will not be able to control or program Insteon devices from the ISY. ISY programs that control Insteon devices - for example, turn lights on at particular times of the day - would also not work.
If you only used the ISY for configuring your Insteon devices you might not notice a dead PLM until the next time you need to make configuration changes.
When I reset the PLM, I get the flashing light sequence then it goes dark. When I press buttons on any Insteon switches/keypads I don't get any flashing of the light on the PLM.
Also, as stated earlier, I still don't see the PLM connected the the ISY when I check the status of the PLM.
It looks like I will have to call smarthome and get an RMA#.
Wayne
Yes, sounds like your PLM needs to be replaced.
Thanks for the help,
Wayne
  • 1 month later...
Just got a replacement PLM. How should I proceed? Should I start by doing a restore PLM?
Wayne
Hi Wayne,
All you have to do is:
1. Make sure you have Event Viewer on level 3
2. Put your RF devices in programming mode
3. Click on to File | Restore Modem (PLM)
When done - and if and only if you get a Request Failed - look at your event viewer to see which devices failed. For each that failed, please do Restore Device on that device.
Wayne
Thanks, I'll give it a whirl and report back later.
Wayne
