Continuous restart
I need help with my isy 994i (1120) reboots every 30 seconds
I do not know what to do, already i made a factory recet an the problem persists
Welcome to the forums!
This is very unfortunate! Have you made sure your PLM is plugged and warmed up for a few seconds first, before powering up your ISY?
Did you do a reset or a total factory reset?
If you did a total factory reset? I believe you have to use a backup to put all the devices information back into the ISY994i.
Here is information on the front panel LED's. How they are operating may also give you a clue. https://wiki.universal-devices.com/index.php?title=Main_Page#Resetting_Your_ISY
One more thought. It maybe a wall wart power supply getting flaky. If it is  rebooting all the time. I have seen wall warts going bad. Causing all kinds of strange things. I believe there was also a message here where the wall wart was causing issues.
Edited by Brian H
