why can't turn off the lights?
Hi
I try to use the following program to turn off some lights, but it doesn't work. Can someone give some advice?
@jzh
How are you triggering the program to run? I see no triggers in the "If" section.
Also:
Did you know you can right click on the program title in the program tree, and select "copy to clipboard" then paste it into a post?
@larryllix: thanks, I learned how to copy/paste :-)  Actually, I know there's no condition, when I 'run (if)', some lights can be turned off, some not.
F1_Lights Off - [ID 001C][Parent 0001]
        Set 'F1_Lights / F1_Breakfast_Spotlight' Off
        Set 'F1_Lights / F1_DinnerRm_Spotlight' Off
        Set 'F1_Lights / F1_Gate(Out)_Light' Off
        Set 'F1_Lights / F1_GateHall_Spotlight' Off
        Set 'F1_Lights / F1_Kitchen_Spotlight' Off
        Set 'F1_Lights / F1_Laundry_Light(N-A)' Off
        Set 'F1_Lights / F1_LivingRm_SpotLight' Off
        Wait  1 second
        Set 'F1_Lights / F1_Office_SpotLight' Off
        Set 'F1_Lights / F1_Deck_Light' Off
Edited by jzh
I would create a scene and and all lights to that scene as responders. Then program the scene itself to turn off.
Since there is a one second wait prior to the last 2, of they are on dimmers, changing the ramp rate can accomplish the same or you can simply and them to the program as you've already done
Edited by lilyoyo1
