oneklakes Posted January 7, 2022 Share Posted January 7, 2022 No data just for the new sensor that I added. It shows at "Sensor 1" in the NS and AC but temperature reading is "1" and all of the other fields (i.e. humidity, feels like) are blank. I restarted the NS multiple times and deleted and reinstalled it in both the same and different slots and I still get the same problem. Link to comment Share on other sites More sharing options...
oneklakes Posted January 7, 2022 Share Posted January 7, 2022 Also, the correct data is showing on the Ambient Weather dashboard for the WS (Observer IP). Link to comment Share on other sites More sharing options...
simplextech Posted January 8, 2022 Author Share Posted January 8, 2022 6 hours ago, oneklakes said: No data just for the new sensor that I added. It shows at "Sensor 1" in the NS and AC but temperature reading is "1" and all of the other fields (i.e. humidity, feels like) are blank. I restarted the NS multiple times and deleted and reinstalled it in both the same and different slots and I still get the same problem. What version are you running. There's different versions and I know the @bpwwer also has an Ambient Weather nodeserver so we need to determine which NS you're running and the version. If you can attach the logs those will be needed to see what the problem may be. Link to comment Share on other sites More sharing options...
oneklakes Posted January 8, 2022 Share Posted January 8, 2022 I'm running your NS version 0.1.35 on Firmware 5.3.3. I've restarted the NS this morning and have attached the log file from the time it started up. I really appreciate your help on this! ambientweather-0021b90243c7-11 (2).txt Link to comment Share on other sites More sharing options...
simplextech Posted January 8, 2022 Author Share Posted January 8, 2022 48 minutes ago, oneklakes said: I'm running your NS version 0.1.35 on Firmware 5.3.3. I've restarted the NS this morning and have attached the log file from the time it started up. I really appreciate your help on this! ambientweather-0021b90243c7-11 (2).txt 114.85 kB · 0 downloads Are you running this on Polisy or on Polyglot cloud? Based on the log error this is running in Polyglot Cloud. It's throwing a key error during processing of the output. 2022-01-08 18:38:46,028 [Controller] [INFO ] Updating Driver ec629b6wnd - GV1: 2.68 uom: 48 self.run() File "/usr/local/lib/python3.7/threading.py", line 865, in run File "/usr/local/lib/python3.7/threading.py", line 917, in _bootstrap_inner self._target(*self._args, **self._kwargs) self.shortPoll() File "/usr/local/lib/python3.7/site-packages/pgc_interface/pgc_interface.py", line 795, in _parseInput File "./ambientweather-poly.py", line 55, in shortPoll File "./ambientweather-poly.py", line 319, in ambient_weather_update self.ambient_weather_update() self.nodes[naddr].setDriver('GV2', last_data['maxdailygust']) KeyError: 'ec629b6fl' Link to comment Share on other sites More sharing options...
oneklakes Posted January 8, 2022 Share Posted January 8, 2022 Running on Polygot cloud. Link to comment Share on other sites More sharing options...
simplextech Posted January 8, 2022 Author Share Posted January 8, 2022 4 minutes ago, oneklakes said: Running on Polygot cloud. That's what it looked like. I recommend you check if @bpwwerAmbient Poly runs in PGC as well. We combined the NS and his version is what is supported. My version of Ambient Weather needs to be removed from the NS store listing and then possibly some renaming if Bob wants. Link to comment Share on other sites More sharing options...
oneklakes Posted January 8, 2022 Share Posted January 8, 2022 Just now, simplextech said: That's what it looked like. I recommend you check if @bpwwerAmbient Poly runs in PGC as well. We combined the NS and his version is what is supported. My version of Ambient Weather needs to be removed from the NS store listing and then possibly some renaming if Bob wants. His NS does have a PGC version so I will check with him. Thanks a bunch for looking into this since I know you moved on to other projects. Link to comment Share on other sites More sharing options...
simplextech Posted January 8, 2022 Author Share Posted January 8, 2022 7 minutes ago, oneklakes said: His NS does have a PGC version so I will check with him. Thanks a bunch for looking into this since I know you moved on to other projects. Please do check with him as he has been supporting the weather services much more than I have been. He and I discussed a while ago about combining them and reducing duplicates/confusion of certain nodeservers to simplify options and support. Link to comment Share on other sites More sharing options...
