Ring Lighting Interface
Good morning,
I am now using the Poly Cloud Ring interface. Working well.  Any chance that this can be interfaced with the Ring Lighting modules?
Andrew
@andrewherman  If you are referrring to the Smart Lighting from Ring, I don't believe there is any plan to incorporate it into the node server.  I have asked about it a few times and have not gotten any type of positive reaction.  The alexa app does integrate with Rings smart lighting and it is possible to create alexa routines to use the motion sensor or light on/off in them.  It is also possible to use the alexa app to fire a program on ISY using lights or motion sensors as triggers.  It is possible to also have the alexa app set a varibale on the ISY for motion or light function to use in other ISY programs.  Its not as clean as the node server but you can get all the same results.
The above refers to the RIng Smart Lighting that works with the Ring Beams Hub, not the hardwired cam/flood lights, from what I understand those will be recognized by the node server.
