Please help installing Polyglot
3 minutes ago, simplextech said:
This next test will require you to edit a file.
  • Filename:
    • /boot/cmdline.txt
  • Entry to Add:
    • ipv6.disable=1
From the command line you can use vi or nano
sudo nano /boot/cmdline.txt
Add the ipv6.disable=1 entry to the very end of the line in the file.  There are spaces between the different parameters.
Example:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=c0f35752-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait ipv6.disable=1
Save this file and then reboot.I
How do I save it?  It says "modified" after adding. Do I just reboot now?
I figured it out. It is saved and I rebooted.
I still get this after rebooting.
pi@raspberrypi:~ $ netstat -an |grep tcp |grep LISTEN
tcp        0      0 127.0.0.1:28017         0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN
Since it's still not getting a listen socket then it's not the weird ipv6 issue that hit me a while back.  So I'm at a loss now.  I'm thinking the install is still missing something.  The polyglot process is running but it doesn't have a listen port which is not correct.
I've never installed on a Raspbian Desktop system as I don't use the desktop so I don't know if there's some conflict there or something... I just don't know.
Well thank you for all of your help. I’m going to start off and install lite.
Hopefully that just works.  I do recommend setting up SSH with lite and doing copy/paste from you Mac to make it a lot easier especially for the install command.
Lite contains less command files and is trimmed down. I doubt that will help.
Your error looked like a missing security file to me. You have to learn to ignore that and continue using the hidden details option.
PolyGlot is refusing the connection because you used https and your browser is choking on the response with bad responses because Polyglot does not supply a certificate  and the browser is hiding the ignore  bypass in "Details"
Here is what Windows gets every login without a signed certificate
Wow.  So it could be that simple?  I clicked on details and got the below.  I don't see a way to bypass.
Check your Internet connection
Check any cables and reboot any routers, modems, or other network devices you may be using.
Allow Chrome to access the network in your firewall or antivirus settings.
If it is already listed as a program allowed to access the network, try removing it from the list and adding it again.
If you use a proxy server…
Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server: Go to Applications > System Preferences > Network > Advanced > Proxies and deselect any proxies that have been selected.
hmmmmm. I am not an iPerson so I don't know much about that. There is a hint there. Allow Chrome to access the network in your firewall settings. Short of that you may need to learn how to create a self-signed security certificate for PolyGlot. I never bothered but I can always bypass the refusal to connect.
Geeeezzzz...try to connect to it from the browser on the RPi. I take it you are using the GUI screen with browser.
localhost:3000 should get it.
I starting over using Raspberry lite. I'm trying to ssh from my Mac but get the error below.
Last login: Sat Aug  3 23:01:43 on ttys000
MacBook-Pro:~ XXXXXXXX$ ssh pi@192.168.1.138
@    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:G/d5U47YsfB0a/qEKCrNqkHrr4PnTbdH/pKzDwQZPwc.
Please contact your system administrator.
Add correct host key in /Users/XXXXXXXX/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /Users/XXXXXXXXX/.ssh/known_hosts:1
ECDSA host key for 192.168.1.138 has changed and you have requested strict checking.
Host key verification failed.
Edited by smarthome_newbie
MacBook-Pro:~ nickengel$
It's harmless you just need to remove the entries in the known_hosts file.
I don't know where on a Mac this is located though.  It should be in your home directory under .ssh/known_hosts so on linux that would be ~/.ssh/known_hosts
for now try using ssh like this to the pi
ssh -o StrictHostKeyChecking=no hostname
And here's a google search stack exchange link you can review...
https://apple.stackexchange.com/questions/204410/disable-stricthostkeychecking-in-ssh
I'm doing something wrong.  I entered the below, but changed "hostname" to the ip of the Rpi.  I'm getting permission denied and message below.  Any ideas?  I can't figure out how to remove entries of the known_hosts file in my Mac.  Is that what has to be done?
Offending ECDSA key in /Users/xxxxx/.ssh/known_hosts:1
Password authentication is disabled to avoid man-in-the-middle attacks.
Keyboard-interactive authentication is disabled to avoid man-in-the-middle attacks.
That right there tells you the location of the file you need to edit.  Remove the keys in that file and then save it.
I typed in the wrong command and got the below. What did I permanently add?  That's the IP of my Rpi.  Sorry, I'm not understanding.  How do I edit the offending key? What keys need to be removed?
$ ssh -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null 192.168.1.138
Warning: Permanently added '192.168.1.138' (ECDSA) to the list of known hosts.
I've made some progress.  I found the below instructions on another site.  See screenshot below. I have downloaded Nano and am now able to edit.  I'm just not sure exactly what or how to edit.  Thanks.
https://imgur.com/Emy8o2E
Also, do I need to be worried for security reasons that I added the below permanently?
