Insteon Engine???
Problem adding new device:  I get an error message stating "Cannot determine Insteon Engine".  What does that mean?  What can I do about it?  Sometimes repeated attempts are successful.  Not always???
Welcome to the forums!!
"Cannot determine Insteon Engine" means that ISY cannot read the profile from the remote Insteon device.
Try a different location for the PLM or a different location for the device. It sounds like you have noise on your powerlines. Some so-called "surge suppressors" or power bars are signal suckers, avoid them. Garage door openers and some switching walwart power supplies are noise makers. Try an isolated panel  breaker circuit for both the devices and try again.
In addition to what was suggested above, do you have both sides of your powerline legs properly bridged using dual band devices?
