August 3, 20197 yr Yes, that’s how to create 3 (or more) way switch scenarios with Insteon. However, a controller can only be a controller (as opposed to a responder) in one scene.
August 3, 20197 yr Author So, a scene can have multiple devices added as controllers. But, a controller can only be a controller on one scene?
August 3, 20197 yr 1 hour ago, BillyD said: So, a scene can have multiple devices added as controllers. But, a controller can only be a controller on one scene? Correct. If you need more mixing and matching logic (I mean, I do) I have a second scene fire via a quick program on the ISY. This is great if, for instance, if you want Scene A to also trigger Scene B, but not vis versa. There's about a half a second lag to fire the second scene.
August 4, 20197 yr Author Thanks, Jec6613. This a bit out of my current level of expertise, but I'll keep it in mind as I progress.
