Node Types Documentation [id]_fam.xml
Hi,
I am looking at [id]_fam.xml files and ISY-WS-SDK and ISY-WS-SDK-Z-Wave for both versions 4.4.6 and 5.0.4.  It appears that the [id]_fam.xml files have not been updated to reflect current devices as the documents do not match ISY-WS-SDK-Z-Wave section 7.3. Also I have an Insteon device which for which a nodeSubCategory is not listed.
If I am reading the docs correctly The insteon Device <type>  has the following format:
"device category.device subcategory.version.reserved"
So,  <nodeCategory id="0" name="Controllers" >, but nodeSubCategory id=26 is not listed in 1_fam.xml.  It appears there should be a few devices between the last id=18 and 26. If this is true where could I find this information?
<node flag="0">
<address>3E EC D2 8</address>
<name>mini - G</name>
<parent type="3">57752</parent>
<type>0.26.57.0</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<startDelay>0</startDelay>
<endDelay>0</endDelay>
<pnode>3E EC D2 1</pnode>
<ELK_ID>P11</ELK_ID>
<property id="ST" value="0" formatted="0" uom="%/on/off"/>
</node>
Also I have the following Z-Wave device
<node flag="128">
<address>ZW005_1</address>
<name>Front Door Battery Level</name>
<family>4</family>
<parent type="3">19023</parent>
<type>4.7.1.0</type>
<pnode>ZW005_1</pnode>
<sgid>1</sgid>
<devtype>
<gen>4.7.1</gen>
<mfg>600.3.130</mfg>
<cat>185</cat>
</devtype>
<ELK_ID>D12</ELK_ID>
</node>
I was able to find the <cat> in the ISY-WS-SDK-Z-Wave but I think UD should update 4_fam.xml doc to reflect current values to help others.
184 = Barrier  (this is the last item in 4_fam.xml in both 4.4.6 and 5.0.4)
185 = Notification Sensor (this is the last item in ISY-WS-SDK-Z-Wave 7.3 in 4.4.6)
186 = Color Switch (this is the last item in ISY-WS-SDK-Z-Wave 7.3 in 5.0.4)
Javier
Edited by Javi
Thanks Michel,
Is there an updated 1_fam also?
