Lutron Wall Plates and Insteon Swithces
Quick question,
Will the Lutron wall switch plates work with the Insteon wall switches?
I need to pick up a 2 gang before the wife gets back home on Monday. This will keep my PAR (Partner Acceptance Rating) in the 90's.
I just replaced 2 switches in an old 50's version of a 4x4 electrical box, which is a lot smaller. One switch controlled a wall outlet under the front window the other the outside front porch light. Hard wired the wall outlet and installed an Insteon on/off switch. Even works.  Two done 13 to go.
