Could Not Create The ZIP file
I am embarassed to to admit it but numerous health issues have kept me for maintaining my ISY to current standards. Sadly, I am still running 4.6.2!!! I have finally reached the place and time where I need to get things updated. I just updated Java to the latest version. I then tried doing a backup. I never have had a problem previously but today I got the message "Could not create the Zip file". I have stopped at that point since I am hesitant to proceed further without a backup. My plan was to first proceed to 4.7.3, get another solid backup and then attempt to upgrade to 5.x.  I am not ashamed to admit that at my age I am not as sharp as I used to be. That and the health issues are at the center of my being so far behind. I would appreciate any help you are willing to provide on this journey.
I checked the error log nd it appers the error in creating the ip file is:
[UDSockets] RSub:31 error:6
Hey SG!
Try entering your java control panel (Windows | Control Panel | java | Permission tab) and re-entering your ISY IP address in the permission table. Your update may have clobbered it.
23 minutes ago, smokegrub said:
Internal or external IP?
Your ISY IP. Java has it's own firewall. The admin console is running under java. Java sees this program/virus trying to write data to a file and tries to stop it. The permissions table  tells java to allow things from that IP address inside your computer.
Thanks for your attempt to help. I made the suggested change then attempted the backup. Would not create the zip file. Actually, I get a file but I get a message that it was not created. The icon that appears only has 56 k.
Edited by smokegrub
I have another ISY located elsewhere. I logged into it and did a backup. No problem.
The size of the backup file that appears on the problematic ISY says cannot create a zip file but then it appears to do so. Is a 56 k file unreasonably small? The one created for the other location was only 26 k. I am reluctant to move forward without what I know to be a solid backup.
Edited by smokegrub
Sorry. I am away from my backups right now so can't comment on the size.
Somebody else jump in here??
Mine are all approx. 156k.  Firmware version (I'm on 5.0.16) might make a difference, as well as how many devices, programs, nodeservers, etc.  I don't have any from the 4.x.x series firmware.
I am beginning to think the file is the proper saize. That leaves the question, is it going to be useful, if needed!!!
Do it again and compare the sizes?
IIRC you can make a copy of the file. Rename it to XXXXXX.zip, Unzip it and then examine the contents. I forget what is in it but I think you will find programs.
Maybe open a ticket with UDI and let them snoop into you ISY and see if it still has a pumping heart. :)
I appreciate all the help, but I am going to take your advice and open a ticket tomorrow. I am also going to need help with the update and especially in going to v 5.x
