johnjces Posted October 26, 2019 Posted October 26, 2019 Issue: (This was emailed prior via the app.) Never had this issue prior to the latest version which my Agave shows as 1.7.130 - Avocado, that was installed on October 11 on both my Samsung G7 and Samsung Tab 10. The service does not seem to start right up when Agave loads as I have it's icon turned on when it is running. It takes multiple tries in either of my two profiles whether I am local to one or away from one. My ISY reports in it's error log at times when trying to turn something on or off -170001 udsockets rsub:44 error:6. Not certain but from what I found something was connecting but not finishing or closing or something like that. Anyway what ever is happening makes Agave really hard to use but after multiple tries it will work. If I use the admin console whether local or remote in either of the 2 location profiles works instantly. Not sure what else you may need. I am connecting directly via port forwarding with Agave and the Java admin console. The service icon comes and goes BTW. Question: I need to change my URLs for my profiles. Is there a procedure to do that? Or do I delete them and start over with the new/updated URLs? I hope there is a non destructive method. Enhancement Suggestion I am a true advocate of the profile name appearing at the top of our home screen. It does show when using Things etc. In an email or forum post along time ago you too thought it a good idea. Just bringing it up again.
