Multiple ISY devices on one Google Home account
Hi folks,
I have had my home working with Google Home and a 994i for years without a problem.  Now purchased a license for a second 994i at a separate location and went through the usual process for uploading the spoken words, etc.  Problem is that my Google Home account does not see this new UUID or Device nor the new light switches added.
In Google Home, I created two "homes"; Home and Cottage.  Under cottage, the new device does not appear and if select add devices, it actually shows Universal Devices already linked but with my home devices.
I even tried un-linking Universal Devices and re-linked to see if it would pick up the new second UUID.  Same result.
I suspect I'm not the first to try this but a quick search found nothing.  Any thoughts?
Hi folks,
On my.isy.io, select "My Profile" and change the option to Use all ISYs in account. That was a feature I requested [emoji16] then you can move them to the proper home in the GH app.
Sent from my Pixel 3 XL with Tapatalk
Works perfectly. Thank you so much. Never paid too much attention to “my profile” all the way in the lonely corner!  Thanks again.
  • 11 months later...
On 11/9/2019 at 8:13 PM, Jimbo said:
On my.isy.io, select "My Profile" and change the option to Use all ISYs in account. That was a feature I requested emoji16.png then you can move them to the proper home in the GH app.
Glad I spotted this thread. Didn't work the way I assumed.  I have 3 ISY's, each in a different home. Created 3 unique users, each with a different preferred ISY.  Thought I would use the appropriate one to associate with each home.  Obviously didn't work.
One question, how do you get programs associated with the correct home?
Paul
Paul
Sorry, not sure I understand your question, can you elaborate a little more?
Sent from my Pixel 3 XL using Tapatalk
