program events
I use several "programs" as flags to indicated the status of doors and windows (open/close, set through the rest interface). Based on these I control lights, e.g.
Program 'Staircase Door' is True
Set 'Light Staircase' On
Wait 3 minutes
Set 'Light Staircase' Off
- No actions
PROBLEM:
Whenever the staircase door is opened, it's associated program becomes true and the above program is run. Oddly enough, the light turns on also if it was previously off and the staircase door is closed. I.e. it appears as if program 'Staircase Door' turning false triggers the then clause of the above program. How can I avoid this?
Bernhard
Bernhard, would you be kind enough to post the contents of your Porogram Staircase?
Wait 3 minutes
- No actions
PROBLEM:
Bernhard
Sure. Is there a convenient way to copy and paste programs?
(Or any other means short of retyping?)
Bernhard
Program Staircase Auto on/off
Program '*Z 1 Laundry Door' is True
Or Program '*Z 15 Entry Downstairs' is True
Or Program '*Z 17 Motion Downstairs' is True
Or Program '*Z 18 Staircase Door' is True
Run Program 'Staircase light on at appropriate level' (If)
Wait 30 seconds
Program Staircase light on appropriate level
From 6:00:00AM
To 9:00:00PM (same day)
Set 'Light Staircase' 25%
You can right-click the Program and choose "Copy To Clipboard".
Below is program Staircsae Door. Since it's used as a flag (controlled from the rest interface), the program is empty.
It just occurred to me that switch bounces would result in the program being set/unset multiple times in rapid succession. I'll look at the log to determine that.
Bernhard
Hi,
Thanks so very much. But, I am very much interested in the program Staircase Door as well. Can you copy paste that as well?
Hi Bernhard,
Thanks so very much. You see, the issue is that you have:
Which means that if any of these conditions are true, then the Then path is executed. Now, the main question is: are you certain that none of these conditions are true when you expect the Else path to run?
I think the best way to test this is to use one condition at a time to isolate which one is actually true when it should NOT be. This way, you can work on the offending condition.
Michel,
You are right, the first condition (*Z 1 Laundry Door) is often true since that door is not always closed.
I'm still puzzled about what's happening:
When is the program run?
Is it when any of the conditions changes? That would explain that when '*Z 18 Staircase Door' turns false, the Then condition is run as long as any of the other conditions (e.g. '*Z 1 Laundry Door') is true.
How can I write the program such that the Then condition is run only when any one of the conditions turns true? Presumably 4 separate programs would do that? Is there a solution with just one program also?
Bernhard
Hi Bernhard,
Hello Bernhard,
Usually I would suggest that you use Control rather than Status as the program would only be triggered on a change. I don't know why you are using the REST interface though.
In any case it would be easier to use 4 programs. Copy program is very useful in that case.
Rand
Michel,
Bernhard
  • 3 weeks later...
I use REST to communicate status changes from the security system to the ISY by setting a program (e.g. '*Z 1 Laundry Door'). Presumably I could call actions from '*Z 1 Laundry Door' directly but prefer not to since that would spread the code controlling the lights all over the place.
Bernhard
Hello Bernhard,
Rand
