No Common
Kentinada
I was going to replace an existing switch today with an INSTEON 2477S but when I opened the switch box, I discovered the only wire in the box is a switch leg. I have no common to connect to the INSTEON switch.  I assume I'm toast with this and can't use INSTEON here?
The 2474 does not require a neutral, but if I recall correctly it is a dimmer, not sure if they have a on/off switch.  I believe they called it a 2 wire.
Is it controlling a light or something else?  There is the Insteon Dimmer that does NOT require a neutral wire.  I have one in use as I didn't feel the need to pull wire for that single light.
I would suggest you may want to pull some other switches just to take a look and see if this is a wide spread problem in your home or just that room/area/switch.
One limitation of the 2474 two wire dimmer. Is it is designed for incandescent load only. Others have found that other types like dimmable LED bulbs may not work.
  • Like 1
That is true.  Which is one reason why I asked about the load.  If it was for a light or something else (like a switched outlet).  I have a switched outlet that this won't work for so I went a different route on that one pending a re-wire when my daughter changes rooms.
Install a Lutron Caseta switch which can handle a good range of lighting types without a neutral wire. Use Polyglot to control it from your Insteon environment.
If you take the micro dimmer approach then you can change the wiring at the fixture so the load wire is instead a neutral wire to the switch box. You can then use any Insteon switch or keypad to control the micro dimmer in the fixture. If you don't want to mess with the wiring then cap off the wires in the switch box and use a remotelinc2 mounted in the switch bracket to control the micro dimmer.
3 hours ago, Brian H said:
If you go with the RemoteLinc2. The bracket is made for a flat surface. If you try and mount it in an electrical box. It will not fit.
This is a complaint I have with the bracket.  I wish SmartHome or someone would 3d print a nice electrical box mount for the RemoteLinc2.  that would be great!  This is something I really love about the Lutron Pico's and their mounting options.
OK, so I don't have any of the RemoteLinc2's.  But just looking at the product, I see the optional wall mount bracket.  Seems like you should be able to use that to screw the remotelinc and a decora switchplate cover into a single entity, then use some hot glue around the edge of the switchplate and glue it to the lip of sheetrock around the single gang box.  Hot glue holds quite well, but not so well that you can't pull it off if you need.
The mount bracket has not "back" to it and only holds the remote in by two touch points (top/bottom) and it uses the "wall" as the backing surface for pressure when pressing the switch.  Without the wall behind the "mount" when you push the remote it wiggles about is horrible and if pressed too hard will pop through the mount into the gang box....
How about cut a piece of flat plastic to the dimensions of the front of the gang box and screw it down using the two screw holes in the gang box top and bottom.  That would give you the back stop.
If it were thick enough plastic to not flex when pushed against then you're creating a flat/hard surface for the mount to rest against just like a wall.  So it would work but it's a lot of work to compensate for a bad mount design from SmartHome :)
I wonder... do they make dimensional gang box covers/fillers that would cover the box and not protrude past the drywall?  I've used the blank plate covers before but that adds thickness and is unappealing having the switch mount attached to that and it's then not easy to put a decorative face plate on top of that.  Hmm...
Wow, this is why this forum is incredibly valuable. Lots of great discussion.  In the end, I just left the old switch alone.  It wasn't worth the added expense or hassle for the desired end result.  Thanks for all the ideas though!
36 minutes ago, Brian H said:
Here is the brackets page. Near the bottom of the page. It says not for mounting over an electrical box.
https://www.smarthome.com/mini-remote-wall-mount-bracket.html
Presumably for the reason listed above . . . it would pop out of the bracket backwards when pushed on.  A gang box cover like I described would effectively make the gang box flush and flat with the surrounding wall and solve that issue.  A standard single gang box "blank" run through your handy table saw to trim the edges back to the same dimensions as the gang box itself would cost about 50 cents and take about 1 minute to cut . . . provided you have a table saw ready to go.  Then it would slip inside the sheetrock edges and, provided the gang box is at least a little deeper than the sheetrock, be flush, with the possible addition of some washers in the event that the gang box were mounted very deeply.  I don't see any reason why this wouldn't also pass code.  It is a code compliant plastic gang box cover that you are using.
1 hour ago, upstatemike said:
I wonder if a Lutron Pico wall bracket could also be used as backing for an Insteon RemoteLink2 ? Just holding the pieces in my hand suggest it could be made to work
No they aren't compatible.  The way a Pico fits into the bracket won't work with the RemoteLinc2.  I've tried as I have both.  If trying to hack something the piece of plastic or cut down plate to go over the gang box is the best route.
  • 1 month later...
You can always run a new NMD-90 or a separate neutral to the box. I ended up having to do this for about half of my switches and all of my outlets (to get a ground). It means cutting holes in your walls and it's a lot of work, but can be very rewarding and you learn a lot. My 1958 house has had about 80% of the electrical replaced at this point (slowly over about 5 years), but it adds value (at least in my case) and gives peace of mind.
Sent from my SM-N9500 using Tapatalk
3 hours ago, fman47 said:
I have the same problem, what did you end up doing
What are you trying to do?  What's the end-goal?  I understand the problem is you don't have a neutral at the switch however a "solution" depends on what you have already, what you're willing to buy or work you're willing to do or have done to meet the end-goal.
Posted (edited)
If it were me and I wanted insteon (or z-wave or similar) at the switch location and all I had was a switch loop, I would go to the fixture box (where the switch loop is initiated) and repurpose the wires to the switch as hot and neutral.  In the fixture box I would add a micro module, to which the load would be connected and by which the load would be controlled.  At the switch box, I now have hot and neutral and I would install a standard insteon switch, capping off the red "load" wire.  Once everything is installed, I would link the switch to the micro module.  Done.  No wires.  No mess.  No fuss.
Edited by oberkc
  • Thanks 1
      38.2k
      381.2k
