2844-222 Insteon Motion Sensor II - USB cable
Is the 90 degree microUSB connector required? Looking at the manual it only seems needed if the back cover is installed.
1) Can the back cover be modified to accept a straight in microUSB connector?
2) On the right angle microUSB connector, does the flat side of the connector face the cable or away from the cable?
If using the back cover and don't want to modify the cover then you need the 90 degree cable. There's an indention on the cover that you could drill through if you wanted to use a straight cable (fill once done with silicone if desired) since it's a soft plastic. I've included some pictures of that would help
