Ceiling Fan Controlled by HS-FS100
Hello,
I am new to the forum.
I have a ceiling fan which is controlled by GE Z-wave Fan-switch.
And I'm using HomeSeer FS100 Flex Sensor to read temperature.
How do i program to achieve:
sensor temperature 70° F to 80° F  would set fan speed to 70%
above 80° F would set fan speed to 100%
below 70° F would set fan Fast-OFF
I'm using ecobee remote sensor and I only adjust mine in the bedroom at night, but I think you'll get the idea.
Happy New Year and welcome.
MBR fan off - [ID 007D][Parent 004D]
        From     2:00:00AM
        To       6:00:00AM (same day)
    And 'Master ceiling fan' Status > 0%
    And 'ecobee / ecob down tstat / ecob down MBR snsr' Temperature < 70.0°F
    And 'ecobee / ecobee Controller' NodeServer Online is True
    And 'ecobee / ecob down tstat / ecob down MBR snsr' Responding is True
        Set 'Master ceiling fan' Fast Off
MBR fan low - [ID 007C][Parent 004D]
        From    11:50:00PM
        To       6:00:00AM (next day)
    And 'Master ceiling fan' Status > 33%
    And 'ecobee / ecob down tstat / ecob down MBR snsr' Temperature < 72.0°F
        Set 'Master ceiling fan' 33%
Thank you TexMike,
I don't know how you get this?:
"And 'ecobee / ecobee Controller' NodeServer Online is True"
I don't have that option.
Here what i did,
and it doesn't work.
Others know much more about this than I do, but my suggestion is :
delete first line from IF as I think that is not needed.
second line of IF :   And............ > 69
third line of IF: .And.............< 81
Furthermore, at least with my Zwave fan controllers, there are 4 % levels :  0% -  34%  - 67%  - 100 % . If I would set my fan to 70%, then it would actually run at 100%. You would have to set it at 66% (or anywhere between 34 and 66 %) to achieve medium power.
Therefore  I would suggest THEN.: Set fan at 66 %
Edited by asbril
I might be wrong but you are using celsius in your program which means that means it would have to be greater than 158 degrees F for it to  trigger the 70% fan.  Just seems a bit warm.
Thank you Tom, you absolutely right. I didn't pay attention to it. Because when you select temperature during programming it's says Fahrenheit.
@Leo I believe you need to look at what @asbril said above too.  It looks like you are turning  the fan off, in one program, and the fan on, in another program,  to 70% both when temp equals 70 one should probably be greater or less than.  Otherwise I think you will have a conflict or possibly create a loop.
Thank you, I didn't know. And it's wouldn't let me highlight
@Leo Sorry for late reply, as I said I'm using ecobee remote sensors for temp instead of a temp sensor, I was just showing example of how a program works to control fan speed. Looks like you've got a lot of good feedback and hopefully on your way to get your desired functionality.
Edited by TexMike
update
Thank you to everyone taking time to help me on this issue. I think my issue was Celsius vs Fahrenheit. For some reason it's flipping between both.
I changed everything to celcius and hopefully it will work as designed.
I will be back testing my project after January 8.
God bless you all.
