Log file analysis w/o Excel
I have moved away from Micro$oft Office and find I can do most of what I need with Google Docs. However, I'm no longer able to analyze an ISY log file. I can generate a .txt log file, but it is not as easy to analyze as a spreadsheet. I have the Excel viewer installed, but when I try to send the log file to Excel it opens the viewer, but doesn't populate. I assume this is because the export process want to run a macro that is not supported in the viewer. Is there a way to export the log to an Excel file so I can analyze with the Excel viewer or Google Sheets?
Thanks, Mike
Turns out the .txt file is tab delimited and imports just fine into a Google sheet.
