Google Home can no longer sync devices
9 minutes ago, bmercier said:
no error message when I did it just now.
"Spokens successfully sent to Google Home."
since then I have to go put everything back in their rooms which is very tedious and time consuming...
If the ‘Room’ assigned to a device in the ISY Portal matches a ‘Room’ available in Google Home - then you won’t have to do this. It will happen automagically for each device. If the room name does not have a match, it will be unassigned in Google Home and you will have to manually assign it. At least it did the last few times I relinked.
Yes I had hoped that was the case but not one of them ended up in a GH room.
Sent from my Pixel 3 XL using Tapatalk
