February 16, 20206 yr I'm honestly not sure how long this has been the case, but I have an inline relay Insteon device which as far as I can tell should already be in my ISY994i, but which just isn't showing up. Its only controller is a button on an 8-button panel. There's a scene set up for it in the ISY. The scene doesn't show the responder device; the responder device isn't listed in the network. If I look at the links on the device, I can actually see the correct address, but just can't find the device itself. Communication to said relay has been *really* flaky, and I would like to try troubleshooting it, but without having the device visible in the admin console, I'm not even sure where to start. I've tried to add the device, but I get an error in the event viewer saying "Device already added, ignored". What can I do to get this thing back to the land of the living so I can start poking and prodding it to figure out why it's no longer reliable?
February 17, 20206 yr @FoxFireX, First, sort the device table by Address. This way, you can find your device. What I recommend, and barring defective devices works over 95% of the time, is to move your PLM to a different outlet and one which is not shared with other transformers and power supplies. With kind regards, Michel
February 19, 20206 yr Author On 2/17/2020 at 1:13 PM, Michel Kohanim said: @FoxFireX, First, sort the device table by Address. This way, you can find your device. What I recommend, and barring defective devices works over 95% of the time, is to move your PLM to a different outlet and one which is not shared with other transformers and power supplies. With kind regards, Michel Huh. Okay, thanks for that. I feel stupid now. I have two separate sets of lights; one of them is on the in-line and the other, I didn't think about its connection because it was working. Turns out the in-line was working fine, controlling the other lights. Found the correct thing to try to add; now I have to figure out if this is a faulty module. Thanks for the suggestion!
