Alexa Devices
I have had Alexa set up with my ISY and working well.  I had a switch go bad and replaced it.  I reprogrammed in the ISY and it works fine.  When I rescan for devices in Alexa it keeps coming up with the old device.  I "Forget" it and rescan but it continues to come up with the old device.  Device name for the old and new switch are the same but renaming it does not help - Alexa continues to see the old switch and not the new one.  Any ideas?
Have you removed the old device form the Alexa list of devices in the UDI portal and added the new device to UDI portal? Once you do this then ask Alexa to discover devices.
Edited by dbuss
No - I forgot all about the portal.  I made the changes in the administrative console and thought that would do it.  Thanks - that solved it.
