March 14, 20206 yr I am a Linux oldtimer, but new to the ISY994. My router assigns it a IP# and I can connect to that but get stopped by a ask for user/PW which anything I try fails. Ubuntu system. Edited March 14, 20206 yr by JimLill
March 14, 20206 yr Are you attempting to access from a web browser? if so, are you getting a username/password box? did you try admin for both the username and password? https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Resetting_Your_Userid/Password
March 14, 20206 yr 30 minutes ago, JimLill said: I am a Linux oldtimer, but new to the ISY994. My router assigns it a IP# and I can connect to that but get stopped by a ask for user/PW which anything I try fails. Ubuntu system. What web interface are you trying to reach? There's a basic web interface for control but that's all. To configure and manage the ISY you need to use the ISY Admin Console which is a java app that is installed and loaded through Java Web Start. Easy way is install the actual Oracle JRE and use that. Hard way is to go play around with the OpenJDK and IcedTea.
March 15, 20206 yr 19 hours ago, simplextech said: Easy way is install the actual Oracle JRE and use that. Hard way is to go play around with the OpenJDK and IcedTea. Agree with this entirely. I've only been able to effectively use IcedTea to start the Admin Console by using the '-- nosecurity' flag. The default username/password for the ISY is admin/admin. Also, use the ISY Launcher to access into your Admin Console locally:
