ISY keeps going offline
My ISY all of a sudden has started killing it self with DNS requests, I have restored it from scratch, changed to different dns servers, switched from DHCP to static I don't know what else to do.
errors start 2020/04/09 09:51:02 System -140000 my.isy.io about 8 times then Failed DNS about 712 times
2020/04/09 16:43:26 System -170001 [Network-DNS][Task=22] Failed DNS 709/rc=6
2020/04/09 16:43:26 System -140000 my.isy.io
2020/04/09 16:44:01 System -170001 [Network-DNS][Task=22] Failed DNS 710/rc=6
2020/04/09 16:44:01 System -140000 my.isy.io
2020/04/09 16:44:36 System -170001 [Network-DNS][Task=22] Failed DNS 711/rc=6
2020/04/09 16:44:36 System -140000 my.isy.io
2020/04/09 16:45:11 System -170001 [Network-DNS][Task=22] Failed DNS 712/rc=6
Edited by kccustom
How many devices do you have on one DHCP server/router?
48 on a UniFi Security Gateway 3P
It was working for weeks after I changed from a Google fiber network box.
I am running 52-55 devices simultaneously (I have another 25 WiFi bulbs that don't appear some of the time) on an ASUS AC1900 router and using the DD-WRT Merlin firmware it complains about shortages of NVRAM all the time. Advice is to use less DHCP titling etc.. or...factory reset and reload  profile image back in which worked once but not any more.
I suspect when the power goes out and come back on it sends out some "Hey! I'm alive" signal to all the devices and they are supposed to ask for an IP address from the DHCP server. Now when about 50 devices start asking, some must get kicked to the curb a few times and some devices finally give and never ask again.
I am suspecting this has happened to my polisy a few times. This last time it was unresponsive and after a power cycle the log showed it attempting to contact my ISY using IP address 0.0.0.0. The router won't let that through and ISY would not answer it using that IP address.
IOW: I suspect the polisy/polyglot gives up too easily and never attempts to heal as it doesn't know IP 0.0.0.0 is not a good thing. This may vary with different devices, depending on who gets the short straw when the router reboots.
This is my third router on this, and about the 20th firmware update. I have ordered a latest style unit, should be here this week, and I'll see what happens with it. It is hard to reproduce but I suspect it only happens with devices that arrive to the gate last and have weak DHCP client systems.
That shouldn't even dent a USP.  In your dashboard what does the USP resources look like?
How is the ISY connected to the network?
@MWareman touched on this in another recent thread.
It's not the traffic for normal data. I think the problem is devices that give up asking for an IP address from a bogged down DHCP server. I finally set my ISY to a fixed IP address that matches my DHCP server. It had failed to get an IP address and just gave up a few times on me now. The only recovery was to power cycle it when no other devices are rebooting. Now this is starting to happen with my polisy.
I have many Ethernet devices that are connected through another router, but rely on the same DHCP server to get an IP address at the same time right after the DHCP server boots up. These devices  may get first dibs on DHCP access/response and other devices take their turns at random getting last service.  If some devices give up after x tries or x seconds, they never get access on the LAN again  because they don't have a valid IP address.
Here is log from my polisy failing to connect to my ISY after my router was power cycled a few times. It knew ISY's IP address but was attempting to connect through the router with IP address 0.0.0.0. Not gonna' work.
51 other devices got IP addresses, and healed just fine.
2020-4-9 00:29:34 [polyglot] error: ISY: connection failed. Retrying... Error: connect ENETUNREACH 192.168.0.161:80 - Local (0.0.0.0:34513)
2020-4-9 00:29:34 [polyglot] error: ISY: connection failed. Retrying... Error: connect ENETUNREACH 192.168.0.161:80 - Local (0.0.0.0:34514)
2020-4-9 00:29:34 [polyglot] info: MQTTS: polyglot authenticated successfully.
2020-4-9 00:29:34 [polyglot] info: MQTTS: Client Connected:
2020-4-9 00:29:34 [polyglot] error: ISY: connection exceeded max re-tries. Aborting. Error: connect ENETUNREACH 192.168.0.161:80 - Local (0.0.0.0:34515)
2020-4-9 00:29:34 [polyglot] error: ISY: RequestError: Error: connect ENETUNREACH 192.168.0.161:80 - Local (0.0.0.0:34515)
2020-4-9 00:29:34 [polyglot] error: Ecobee(1): NS getNodesFromISY RequestError: Error: connect ENETUNREACH 192.168.0.161:80 - Local (0.0.0.0:34515)
I have tried both ways static on the ISY and DHCP, I have a port forwarded on the router so the ISY has to be static there, Michael, K. directed me to the wiki that said in my port forwarding rules to only allow TCP which I have done.
I have tried 8.8.8.8 the router gateway 192.168.1.1 and my AdGuard adblocker ip, I am noticing it seems to happen when I access it from work right after I log off.
2020/04/13 06:46:33  System    -5012	31
2020/04/13 06:46:33  System    -5012	39
2020/04/13 06:46:33  System    -5012	0
2020/04/13 06:46:38  System    -140000	sub.isy.io
2020/04/13 06:46:38  System    -5013	0
2020/04/13 06:46:47  System    -140000	my.isy.io
2020/04/13 06:47:22  System    -140000	my.isy.io
2020/04/13 06:47:57  System    -140000	my.isy.io
2020/04/13 06:48:32  System    -140000	my.isy.io
2020/04/13 06:49:07  System    -140000	my.isy.io
2020/04/13 06:49:42  System    -140000	my.isy.io
2020/04/13 06:50:17  System    -140000	my.isy.io
2020/04/13 06:50:52  System    -140000	my.isy.io
2020/04/13 06:51:27  System    -140000	my.isy.io
2020/04/13 06:52:02  System    -170001	[Network-DNS][Task=22] Failed DNS 11/rc=6
2020/04/13 06:52:02  System    -140000	my.isy.io
2020/04/13 06:52:37  System    -170001	[Network-DNS][Task=22] Failed DNS 12/rc=6
2020/04/13 06:52:37  System    -140000	my.isy.io
2020/04/13 06:53:12  System    -170001	[Network-DNS][Task=22] Failed DNS 13/rc=6
2020/04/13 06:53:12  System    -140000	my.isy.io
2020/04/13 06:53:47  System    -170001	[Network-DNS][Task=22] Failed DNS 14/rc=6
2020/04/13 06:53:47  System    -140000	my.isy.io
2020/04/13 06:54:22  System    -170001	[Network-DNS][Task=22] Failed DNS 15/rc=6
2020/04/13 06:54:22  System    -140000	my.isy.io
2020/04/13 06:54:57  System    -170001	[Network-DNS][Task=22] Failed DNS 16/rc=6
2020/04/13 06:54:57  System    -140000	my.isy.io
2020/04/13 06:55:32  System    -170001	[Network-DNS][Task=22] Failed DNS 17/rc=6
2020/04/13 06:55:32  System    -140000	my.isy.io
2020/04/13 06:56:07  System    -170001	[Network-DNS][Task=22] Failed DNS 18/rc=6
2020/04/13 06:56:07  System    -140000	my.isy.io
2020/04/13 06:56:42  System    -170001	[Network-DNS][Task=22] Failed DNS 19/rc=6
2020/04/13 06:56:42  System    -140000	my.isy.io
2020/04/13 06:57:17  System    -170001	[Network-DNS][Task=22] Failed DNS 20/rc=6
2020/04/13 06:57:17  System    -140000	my.isy.io
2020/04/13 06:57:52  System    -170001	[Network-DNS][Task=22] Failed DNS 21/rc=6
2020/04/13 06:57:52  System    -140000	my.isy.io
2020/04/13 06:58:27  System    -170001	[Network-DNS][Task=22] Failed DNS 22/rc=6
2020/04/13 06:58:27  System    -140000	my.isy.io
2020/04/13 06:59:02  System    -170001	[Network-DNS][Task=22] Failed DNS 23/rc=6
2020/04/13 06:59:02  System    -140000	my.isy.io
2020/04/13 06:59:36  System    -170001	[Network-DNS][Task=22] Failed DNS 24/rc=6
2020/04/13 06:59:36  System    -140000	my.isy.io
2020/04/13 07:00:11  System    -170001	[Network-DNS][Task=22] Failed DNS 25/rc=6
2020/04/13 07:00:11  System    -140000	my.isy.io
2020/04/13 07:00:46  System    -170001	[Network-DNS][Task=22] Failed DNS 26/rc=6
2020/04/13 07:00:46  System    -140000	my.isy.io
2020/04/13 07:01:21  System    -170001	[Network-DNS][Task=22] Failed DNS 27/rc=6
2020/04/13 07:01:21  System    -140000	my.isy.io
2020/04/13 07:01:56  System    -170001	[Network-DNS][Task=22] Failed DNS 28/rc=6
2020/04/13 07:01:56  System    -140000	my.isy.io
2020/04/13 07:02:31  System    -170001	[Network-DNS][Task=22] Failed DNS 29/rc=6
2020/04/13 07:02:31  System    -140000	my.isy.io
2020/04/13 07:03:06  System    -170001	[Network-DNS][Task=22] Failed DNS 30/rc=6
2020/04/13 07:03:06  System    -140000	my.isy.io
2020/04/13 07:03:41  System    -170001	[Network-DNS][Task=22] Failed DNS 31/rc=6
2020/04/13 07:03:41  System    -140000	my.isy.io
2020/04/13 07:04:16  System    -170001	[Network-DNS][Task=22] Failed DNS 32/rc=6
2020/04/13 07:04:16  System    -140000	my.isy.io
2020/04/13 07:04:51  System    -170001	[Network-DNS][Task=22] Failed DNS 33/rc=6
2020/04/13 07:04:51  System    -140000	my.isy.io
2020/04/13 07:05:26  System    -170001	[Network-DNS][Task=22] Failed DNS 34/rc=6
2020/04/13 07:05:26  System    -140000	my.isy.io
2020/04/13 07:06:01  System    -170001	[Network-DNS][Task=22] Failed DNS 35/rc=6
2020/04/13 07:06:01  System    -140000	my.isy.io
2020/04/13 07:06:36  System    -170001	[Network-DNS][Task=22] Failed DNS 36/rc=6
2020/04/13 07:06:36  System    -140000	my.isy.io
2020/04/13 07:07:11  System    -170001	[Network-DNS][Task=22] Failed DNS 37/rc=6
2020/04/13 07:07:11  System    -140000	my.isy.io
2020/04/13 07:07:46  System    -170001	[Network-DNS][Task=22] Failed DNS 38/rc=6
2020/04/13 07:07:46  System    -140000	my.isy.io
2020/04/13 07:08:21  System    -170001	[Network-DNS][Task=22] Failed DNS 39/rc=6
2020/04/13 07:08:21  System    -140000	my.isy.io
2020/04/13 07:08:56  System    -170001	[Network-DNS][Task=22] Failed DNS 40/rc=6
2020/04/13 07:08:56  System    -140000	my.isy.io
2020/04/13 07:09:31  System    -170001	[Network-DNS][Task=22] Failed DNS 41/rc=6
2020/04/13 07:09:31  System    -140000	my.isy.io
2020/04/13 07:10:06  System    -170001	[Network-DNS][Task=22] Failed DNS 42/rc=6
2020/04/13 07:10:06  System    -140000	my.isy.io
2020/04/13 07:10:41  System    -170001	[Network-DNS][Task=22] Failed DNS 43/rc=6
2020/04/13 07:10:41  System    -140000	my.isy.io
2020/04/13 07:11:16  System    -170001	[Network-DNS][Task=22] Failed DNS 44/rc=6
2020/04/13 07:11:16  System    -140000	my.isy.io
2020/04/13 07:11:51  System    -170001	[Network-DNS][Task=22] Failed DNS 45/rc=6
2020/04/13 07:11:51  System    -140000	my.isy.io
2020/04/13 07:12:26  System    -170001	[Network-DNS][Task=22] Failed DNS 46/rc=6
2020/04/13 07:12:26  System    -140000	my.isy.io
2020/04/13 07:13:01  System    -170001	[Network-DNS][Task=22] Failed DNS 47/rc=6
2020/04/13 07:13:01  System    -140000	my.isy.io
2020/04/13 07:13:36  System    -170001	[Network-DNS][Task=22] Failed DNS 48/rc=6
2020/04/13 07:13:36  System    -140000	my.isy.io
2020/04/13 07:14:11  System    -170001	[Network-DNS][Task=22] Failed DNS 49/rc=6
2020/04/13 07:14:11  System    -140000	my.isy.io
2020/04/13 07:14:46  System    -170001	[Network-DNS][Task=22] Failed DNS 50/rc=6
2020/04/13 07:14:46  System    -140000	my.isy.io
2020/04/13 07:15:21  System    -170001	[Network-DNS][Task=22] Failed DNS 51/rc=6
2020/04/13 07:15:21  System    -140000	my.isy.io
2020/04/13 07:15:56  System    -170001	[Network-DNS][Task=22] Failed DNS 52/rc=6
2020/04/13 07:15:56  System    -140000	my.isy.io
2020/04/13 07:16:31  System    -170001	[Network-DNS][Task=22] Failed DNS 53/rc=6
2020/04/13 07:16:31  System    -140000	my.isy.io
2020/04/13 07:17:06  System    -170001	[Network-DNS][Task=22] Failed DNS 54/rc=6
2020/04/13 07:17:06  System    -140000	my.isy.io
2020/04/13 07:17:41  System    -170001	[Network-DNS][Task=22] Failed DNS 55/rc=6
2020/04/13 07:17:41  System    -140000	my.isy.io
2020/04/13 07:18:16  System    -170001	[Network-DNS][Task=22] Failed DNS 56/rc=6
2020/04/13 07:18:16  System    -140000	my.isy.io
2020/04/13 07:18:51  System    -170001	[Network-DNS][Task=22] Failed DNS 57/rc=6
2020/04/13 07:18:51  System    -140000	my.isy.io
2020/04/13 07:19:27  System    -170001	[Network-DNS][Task=22] Failed DNS 58/rc=6
2020/04/13 07:19:27  System    -140000	my.isy.io
2020/04/13 07:20:02  System    -170001	[Network-DNS][Task=22] Failed DNS 59/rc=6
2020/04/13 07:20:02  System    -140000	my.isy.io
2020/04/13 07:20:37  System    -170001	[Network-DNS][Task=22] Failed DNS 60/rc=6
2020/04/13 07:20:37  System    -140000	my.isy.io
2020/04/13 07:21:12  System    -170001	[Network-DNS][Task=22] Failed DNS 61/rc=6
2020/04/13 07:21:12  System    -140000	my.isy.io
2020/04/13 07:21:47  System    -170001	[Network-DNS][Task=22] Failed DNS 62/rc=6
2020/04/13 07:21:47  System    -140000	my.isy.io
2020/04/13 07:22:22  System    -170001	[Network-DNS][Task=22] Failed DNS 63/rc=6
2020/04/13 07:22:22  System    -140000	my.isy.io
2020/04/13 07:22:57  System    -170001	[Network-DNS][Task=22] Failed DNS 64/rc=6
2020/04/13 07:22:57  System    -140000	my.isy.io
2020/04/13 07:23:32  System    -170001	[Network-DNS][Task=22] Failed DNS 65/rc=6
2020/04/13 07:23:32  System    -140000	my.isy.io
2020/04/13 07:24:07  System    -170001	[Network-DNS][Task=22] Failed DNS 66/rc=6
2020/04/13 07:24:07  System    -140000	my.isy.io
2020/04/13 07:24:42  System    -170001	[Network-DNS][Task=22] Failed DNS 67/rc=6
2020/04/13 07:24:42  System    -140000	my.isy.io
2020/04/13 07:25:17  System    -170001	[Network-DNS][Task=22] Failed DNS 68/rc=6
2020/04/13 07:25:17  System    -140000	my.isy.io
2020/04/13 07:25:52  System    -170001	[Network-DNS][Task=22] Failed DNS 69/rc=6
2020/04/13 07:25:52  System    -140000	my.isy.io
2020/04/13 07:26:27  System    -170001	[Network-DNS][Task=22] Failed DNS 70/rc=6
2020/04/13 07:26:27  System    -140000	my.isy.io
2020/04/13 07:27:02  System    -170001	[Network-DNS][Task=22] Failed DNS 71/rc=6
2020/04/13 07:27:02  System    -140000	my.isy.io
2020/04/13 07:27:37  System    -170001	[Network-DNS][Task=22] Failed DNS 72/rc=6
2020/04/13 07:27:37  System    -140000	my.isy.io
2020/04/13 07:28:12  System    -170001	[Network-DNS][Task=22] Failed DNS 73/rc=6
2020/04/13 07:28:12  System    -140000	my.isy.io
2020/04/13 07:28:47  System    -170001	[Network-DNS][Task=22] Failed DNS 74/rc=6
2020/04/13 07:28:47  System    -140000	my.isy.io
2020/04/13 07:29:22  System    -170001	[Network-DNS][Task=22] Failed DNS 75/rc=6
2020/04/13 07:29:22  System    -140000	my.isy.io
2020/04/13 07:29:57  System    -170001	[Network-DNS][Task=22] Failed DNS 76/rc=6
2020/04/13 07:29:57  System    -140000	my.isy.io
2020/04/13 07:30:32  System    -170001	[Network-DNS][Task=22] Failed DNS 77/rc=6
2020/04/13 07:30:32  System    -140000	my.isy.io
2020/04/13 07:31:07  System    -170001	[Network-DNS][Task=22] Failed DNS 78/rc=6
2020/04/13 07:31:07  System    -140000	my.isy.io
2020/04/13 07:31:42  System    -170001	[Network-DNS][Task=22] Failed DNS 79/rc=6
2020/04/13 07:31:42  System    -140000	my.isy.io
2020/04/13 07:32:17  System    -170001	[Network-DNS][Task=22] Failed DNS 80/rc=6
2020/04/13 07:32:17  System    -140000	my.isy.io
2020/04/13 07:32:52  System    -170001	[Network-DNS][Task=22] Failed DNS 81/rc=6
2020/04/13 07:32:52  System    -140000	my.isy.io
2020/04/13 07:33:27  System    -170001	[Network-DNS][Task=22] Failed DNS 82/rc=6
2020/04/13 07:33:27  System    -140000	my.isy.io
2020/04/13 07:34:02  System    -170001	[Network-DNS][Task=22] Failed DNS 83/rc=6
2020/04/13 07:34:02  System    -140000	my.isy.io
2020/04/13 07:34:37  System    -170001	[Network-DNS][Task=22] Failed DNS 84/rc=6
2020/04/13 07:34:37  System    -140000	my.isy.io
2020/04/13 07:35:12  System    -170001	[Network-DNS][Task=22] Failed DNS 85/rc=6
2020/04/13 07:35:12  System    -140000	my.isy.io
2020/04/13 07:35:47  System    -170001	[Network-DNS][Task=22] Failed DNS 86/rc=6
2020/04/13 07:35:47  System    -140000	my.isy.io
2020/04/13 07:36:21  System    -170001	[Network-DNS][Task=22] Failed DNS 87/rc=6
2020/04/13 07:36:21  System    -140000	my.isy.io
2020/04/13 07:36:56  System    -170001	[Network-DNS][Task=22] Failed DNS 88/rc=6
2020/04/13 07:36:56  System    -140000	my.isy.io
2020/04/13 07:37:31  System    -170001	[Network-DNS][Task=22] Failed DNS 89/rc=6
2020/04/13 07:37:31  System    -140000	my.isy.io
2020/04/13 07:38:06  System    -170001	[Network-DNS][Task=22] Failed DNS 90/rc=6
2020/04/13 07:38:06  System    -140000	my.isy.io
2020/04/13 07:38:41  System    -170001	[Network-DNS][Task=22] Failed DNS 91/rc=6
2020/04/13 07:38:41  System    -140000	my.isy.io
2020/04/13 07:39:16  System    -170001	[Network-DNS][Task=22] Failed DNS 92/rc=6
2020/04/13 07:39:16  System    -140000	my.isy.io
2020/04/13 07:39:51  System    -170001	[Network-DNS][Task=22] Failed DNS 93/rc=6
2020/04/13 07:39:51  System    -140000	my.isy.io
2020/04/13 07:40:26  System    -170001	[Network-DNS][Task=22] Failed DNS 94/rc=6
2020/04/13 07:40:26  System    -140000	my.isy.io
2020/04/13 07:41:01  System    -170001	[Network-DNS][Task=22] Failed DNS 95/rc=6
2020/04/13 07:41:01  System    -140000	my.isy.io
2020/04/13 07:41:36  System    -170001	[Network-DNS][Task=22] Failed DNS 96/rc=6
2020/04/13 07:41:36  System    -140000	my.isy.io
2020/04/13 07:42:11  System    -170001	[Network-DNS][Task=22] Failed DNS 97/rc=6
2020/04/13 07:42:11  System    -140000	my.isy.io
2020/04/13 07:42:46  System    -170001	[Network-DNS][Task=22] Failed DNS 98/rc=6
2020/04/13 07:42:46  System    -140000	my.isy.io
2020/04/13 07:43:21  System    -170001	[Network-DNS][Task=22] Failed DNS 99/rc=6
2020/04/13 07:43:21  System    -140000	my.isy.io
2020/04/13 07:43:56  System    -170001	[Network-DNS][Task=22] Failed DNS 100/rc=6
2020/04/13 07:43:56  System    -140000	my.isy.io
2020/04/13 07:44:31  System    -170001	[Network-DNS][Task=22] Failed DNS 101/rc=6
2020/04/13 07:44:31  System    -140000	my.isy.io
2020/04/13 07:45:06  System    -170001	[Network-DNS][Task=22] Failed DNS 102/rc=6
2020/04/13 07:45:06  System    -140000	my.isy.io
2020/04/13 07:45:41  System    -170001	[Network-DNS][Task=22] Failed DNS 103/rc=6
2020/04/13 07:45:41  System    -140000	my.isy.io
2020/04/13 07:46:16  System    -170001	[Network-DNS][Task=22] Failed DNS 104/rc=6
2020/04/13 07:46:16  System    -140000	my.isy.io
2020/04/13 07:46:51  System    -170001	[Network-DNS][Task=22] Failed DNS 105/rc=6
2020/04/13 07:46:51  System    -140000	my.isy.io
2020/04/13 07:47:26  System    -170001	[Network-DNS][Task=22] Failed DNS 106/rc=6
2020/04/13 07:47:26  System    -140000	my.isy.io
2020/04/13 07:48:01  System    -170001	[Network-DNS][Task=22] Failed DNS 107/rc=6
2020/04/13 07:48:01  System    -140000	my.isy.io
2020/04/13 07:48:36  System    -170001	[Network-DNS][Task=22] Failed DNS 108/rc=6
2020/04/13 07:48:36  System    -140000	my.isy.io
2020/04/13 07:49:11  System    -170001	[Network-DNS][Task=22] Failed DNS 109/rc=6
2020/04/13 07:49:11  System    -140000	my.isy.io
2020/04/13 07:49:46  System    -170001	[Network-DNS][Task=22] Failed DNS 110/rc=6
2020/04/13 07:49:46  System    -140000	my.isy.io
2020/04/13 07:50:21  System    -170001	[Network-DNS][Task=22] Failed DNS 111/rc=6
2020/04/13 07:50:21  System    -140000	my.isy.io
2020/04/13 07:50:56  System    -170001	[Network-DNS][Task=22] Failed DNS 112/rc=6
2020/04/13 07:50:56  System    -140000	my.isy.io
2020/04/13 07:51:31  System    -170001	[Network-DNS][Task=22] Failed DNS 113/rc=6
2020/04/13 07:51:31  System    -140000	my.isy.io
2020/04/13 07:52:06  System    -170001	[Network-DNS][Task=22] Failed DNS 114/rc=6
2020/04/13 07:52:06  System    -140000	my.isy.io
2020/04/13 07:52:41  System    -170001	[Network-DNS][Task=22] Failed DNS 115/rc=6
2020/04/13 07:52:41  System    -140000	my.isy.io
2020/04/13 07:53:16  System    -170001	[Network-DNS][Task=22] Failed DNS 116/rc=6
2020/04/13 07:53:16  System    -140000	my.isy.io
2020/04/13 07:53:51  System    -170001	[Network-DNS][Task=22] Failed DNS 117/rc=6
2020/04/13 07:53:51  System    -140000	my.isy.io
2020/04/13 07:54:27  System    -170001	[Network-DNS][Task=22] Failed DNS 118/rc=6
2020/04/13 07:54:27  System    -140000	my.isy.io
2020/04/13 07:55:02  System    -170001	[Network-DNS][Task=22] Failed DNS 119/rc=6
2020/04/13 07:55:02  System    -140000	my.isy.io
2020/04/13 07:55:37  System    -170001	[Network-DNS][Task=22] Failed DNS 120/rc=6
2020/04/13 07:55:37  System    -140000	my.isy.io
2020/04/13 07:56:12  System    -170001	[Network-DNS][Task=22] Failed DNS 121/rc=6
2020/04/13 07:56:12  System    -140000	my.isy.io
2020/04/13 07:56:47  System    -170001	[Network-DNS][Task=22] Failed DNS 122/rc=6
2020/04/13 07:56:47  System    -140000	my.isy.io
2020/04/13 07:57:22  System    -170001	[Network-DNS][Task=22] Failed DNS 123/rc=6
2020/04/13 07:57:22  System    -140000	my.isy.io
2020/04/13 07:57:57  System    -170001	[Network-DNS][Task=22] Failed DNS 124/rc=6
2020/04/13 07:57:57  System    -140000	my.isy.io
2020/04/13 07:58:32  System    -170001	[Network-DNS][Task=22] Failed DNS 125/rc=6
2020/04/13 07:58:32  System    -140000	my.isy.io
2020/04/13 07:59:07  System    -170001	[Network-DNS][Task=22] Failed DNS 126/rc=6
2020/04/13 07:59:07  System    -140000	my.isy.io
2020/04/13 07:59:42  System    -170001	[Network-DNS][Task=22] Failed DNS 127/rc=6
2020/04/13 07:59:42  System    -140000	my.isy.io
2020/04/13 08:00:17  System    -170001	[Network-DNS][Task=22] Failed DNS 128/rc=6
2020/04/13 08:00:17  System    -140000	my.isy.io
2020/04/13 08:00:52  System    -170001	[Network-DNS][Task=22] Failed DNS 129/rc=6
2020/04/13 08:00:52  System    -140000	my.isy.io
2020/04/13 08:01:27  System    -170001	[Network-DNS][Task=22] Failed DNS 130/rc=6
2020/04/13 08:01:27  System    -140000	my.isy.io
2020/04/13 08:02:02  System    -170001	[Network-DNS][Task=22] Failed DNS 131/rc=6
2020/04/13 08:02:02  System    -140000	my.isy.io
2020/04/13 08:02:37  System    -170001	[Network-DNS][Task=22] Failed DNS 132/rc=6
2020/04/13 08:02:37  System    -140000	my.isy.io
2020/04/13 08:03:12  System    -170001	[Network-DNS][Task=22] Failed DNS 133/rc=6
2020/04/13 08:03:12  System    -140000	my.isy.io
2020/04/13 08:03:47  System    -170001	[Network-DNS][Task=22] Failed DNS 134/rc=6
2020/04/13 08:03:47  System    -140000	my.isy.io
2020/04/13 08:04:22  System    -170001	[Network-DNS][Task=22] Failed DNS 135/rc=6
2020/04/13 08:04:22  System    -140000	my.isy.io
2020/04/13 08:04:57  System    -170001	[Network-DNS][Task=22] Failed DNS 136/rc=6
2020/04/13 08:04:57  System    -140000	my.isy.io
2020/04/13 08:05:32  System    -170001	[Network-DNS][Task=22] Failed DNS 137/rc=6
2020/04/13 08:05:32  System    -140000	my.isy.io
2020/04/13 08:06:07  System    -170001	[Network-DNS][Task=22] Failed DNS 138/rc=6
2020/04/13 08:06:07  System    -140000	my.isy.io
2020/04/13 08:06:42  System    -170001	[Network-DNS][Task=22] Failed DNS 139/rc=6
2020/04/13 08:06:42  System    -140000	my.isy.io
2020/04/13 08:07:17  System    -170001	[Network-DNS][Task=22] Failed DNS 140/rc=6
2020/04/13 08:07:17  System    -140000	my.isy.io
2020/04/13 08:07:52  System    -170001	[Network-DNS][Task=22] Failed DNS 141/rc=6
2020/04/13 08:07:52  System    -140000	my.isy.io
2020/04/13 08:08:27  System    -170001	[Network-DNS][Task=22] Failed DNS 142/rc=6
2020/04/13 08:08:27  System    -140000	my.isy.io
2020/04/13 08:09:02  System    -170001	[Network-DNS][Task=22] Failed DNS 143/rc=6
2020/04/13 08:09:02  System    -140000	my.isy.io
2020/04/13 08:09:37  System    -170001	[Network-DNS][Task=22] Failed DNS 144/rc=6
2020/04/13 08:09:37  System    -140000	my.isy.io
2020/04/13 08:10:12  System    -170001	[Network-DNS][Task=22] Failed DNS 145/rc=6
2020/04/13 08:10:12  System    -140000	my.isy.io
2020/04/13 08:10:47  System    -170001	[Network-DNS][Task=22] Failed DNS 146/rc=6
2020/04/13 08:10:47  System    -140000	my.isy.io
2020/04/13 08:11:22  System    -170001	[Network-DNS][Task=22] Failed DNS 147/rc=6
2020/04/13 08:11:22  System    -140000	my.isy.io
2020/04/13 08:11:57  System    -170001	[Network-DNS][Task=22] Failed DNS 148/rc=6
2020/04/13 08:11:57  System    -140000	my.isy.io
2020/04/13 08:12:32  System    -170001	[Network-DNS][Task=22] Failed DNS 149/rc=6
2020/04/13 08:12:32  System    -140000	my.isy.io
2020/04/13 08:13:07  System    -170001	[Network-DNS][Task=22] Failed DNS 150/rc=6
2020/04/13 08:13:07  System    -140000	my.isy.io
2020/04/13 08:13:41  System    -170001	[Network-DNS][Task=22] Failed DNS 151/rc=6
2020/04/13 08:13:41  System    -140000	my.isy.io
2020/04/13 08:14:16  System    -170001	[Network-DNS][Task=22] Failed DNS 152/rc=6
2020/04/13 08:14:16  System    -140000	my.isy.io
2020/04/13 08:14:51  System    -170001	[Network-DNS][Task=22] Failed DNS 153/rc=6
2020/04/13 08:14:51  System    -140000	my.isy.io
2020/04/13 08:15:26  System    -170001	[Network-DNS][Task=22] Failed DNS 154/rc=6
2020/04/13 08:15:26  System    -140000	my.isy.io
2020/04/13 08:16:01  System    -170001	[Network-DNS][Task=22] Failed DNS 155/rc=6
2020/04/13 08:16:01  System    -140000	my.isy.io
2020/04/13 08:16:36  System    -170001	[Network-DNS][Task=22] Failed DNS 156/rc=6
2020/04/13 08:16:36  System    -140000	my.isy.io
2020/04/13 08:17:11  System    -170001	[Network-DNS][Task=22] Failed DNS 157/rc=6
2020/04/13 08:17:11  System    -140000	my.isy.io
2020/04/13 08:17:46  System    -170001	[Network-DNS][Task=22] Failed DNS 158/rc=6
2020/04/13 08:17:46  System    -140000	my.isy.io
2020/04/13 08:18:21  System    -170001	[Network-DNS][Task=22] Failed DNS 159/rc=6
2020/04/13 08:18:21  System    -140000	my.isy.io
2020/04/13 08:18:56  System    -170001	[Network-DNS][Task=22] Failed DNS 160/rc=6
2020/04/13 08:18:56  System    -140000	my.isy.io
2020/04/13 08:19:31  System    -170001	[Network-DNS][Task=22] Failed DNS 161/rc=6
2020/04/13 08:19:31  System    -140000	my.isy.io
2020/04/13 08:20:06  System    -170001	[Network-DNS][Task=22] Failed DNS 162/rc=6
2020/04/13 08:20:06  System    -140000	my.isy.io
2020/04/13 08:20:41  System    -170001	[Network-DNS][Task=22] Failed DNS 163/rc=6
2020/04/13 08:20:41  System    -140000	my.isy.io
2020/04/13 08:21:16  System    -170001	[Network-DNS][Task=22] Failed DNS 164/rc=6
2020/04/13 08:21:16  System    -140000	my.isy.io
2020/04/13 08:21:51  System    -170001	[Network-DNS][Task=22] Failed DNS 165/rc=6
2020/04/13 08:21:51  System    -140000	my.isy.io
2020/04/13 08:22:26  System    -170001	[Network-DNS][Task=22] Failed DNS 166/rc=6
2020/04/13 08:22:26  System    -140000	my.isy.io
2020/04/13 08:23:01  System    -170001	[Network-DNS][Task=22] Failed DNS 167/rc=6
2020/04/13 08:23:01  System    -140000	my.isy.io
2020/04/13 08:23:36  System    -170001	[Network-DNS][Task=22] Failed DNS 168/rc=6
2020/04/13 08:23:36  System    -140000	my.isy.io
2020/04/13 08:24:11  System    -170001	[Network-DNS][Task=22] Failed DNS 169/rc=6
2020/04/13 08:24:11  System    -140000	my.isy.io
2020/04/13 08:24:46  System    -170001	[Network-DNS][Task=22] Failed DNS 170/rc=6
2020/04/13 08:24:46  System    -140000	my.isy.io
2020/04/13 08:25:21  System    -170001	[Network-DNS][Task=22] Failed DNS 171/rc=6
2020/04/13 08:25:21  System    -140000	my.isy.io
2020/04/13 08:25:56  System    -170001	[Network-DNS][Task=22] Failed DNS 172/rc=6
2020/04/13 08:25:56  System    -140000	my.isy.io
2020/04/13 08:26:31  System    -170001	[Network-DNS][Task=22] Failed DNS 173/rc=6
2020/04/13 08:26:31  System    -140000	my.isy.io
2020/04/13 08:27:06  System    -170001	[Network-DNS][Task=22] Failed DNS 174/rc=6
2020/04/13 08:27:06  System    -140000	my.isy.io
2020/04/13 08:27:41  System    -170001	[Network-DNS][Task=22] Failed DNS 175/rc=6
2020/04/13 08:27:41  System    -140000	my.isy.io
2020/04/13 08:28:16  System    -170001	[Network-DNS][Task=22] Failed DNS 176/rc=6
2020/04/13 08:28:16  System    -140000	my.isy.io
2020/04/13 08:28:51  System    -170001	[Network-DNS][Task=22] Failed DNS 177/rc=6
2020/04/13 08:28:51  System    -140000	my.isy.io
2020/04/13 08:29:26  System    -170001	[Network-DNS][Task=22] Failed DNS 178/rc=6
2020/04/13 08:29:26  System    -140000	my.isy.io
2020/04/13 08:30:01  System    -170001	[Network-DNS][Task=22] Failed DNS 179/rc=6
2020/04/13 08:30:01  System    -140000	my.isy.io
2020/04/13 08:30:36  System    -170001	[Network-DNS][Task=22] Failed DNS 180/rc=6
2020/04/13 08:30:36  System    -140000	my.isy.io
2020/04/13 08:31:11  System    -170001	[Network-DNS][Task=22] Failed DNS 181/rc=6
2020/04/13 08:31:11  System    -140000	my.isy.io
2020/04/13 08:31:46  System    -170001	[Network-DNS][Task=22] Failed DNS 182/rc=6
2020/04/13 08:31:46  System    -140000	my.isy.io
2020/04/13 08:32:21  System    -170001	[Network-DNS][Task=22] Failed DNS 183/rc=6
2020/04/13 08:32:21  System    -140000	my.isy.io
2020/04/13 08:32:56  System    -170001	[Network-DNS][Task=22] Failed DNS 184/rc=6
2020/04/13 08:32:56  System    -140000	my.isy.io
2020/04/13 08:33:31  System    -170001	[Network-DNS][Task=22] Failed DNS 185/rc=6
2020/04/13 08:33:31  System    -140000	my.isy.io
2020/04/13 08:34:06  System    -170001	[Network-DNS][Task=22] Failed DNS 186/rc=6
2020/04/13 08:34:06  System    -140000	my.isy.io
2020/04/13 08:34:42  System    -170001	[Network-DNS][Task=22] Failed DNS 187/rc=6
2020/04/13 08:34:42  System    -140000	my.isy.io
2020/04/13 08:35:17  System    -170001	[Network-DNS][Task=22] Failed DNS 188/rc=6
2020/04/13 08:35:17  System    -140000	my.isy.io
2020/04/13 08:35:52  System    -170001	[Network-DNS][Task=22] Failed DNS 189/rc=6
2020/04/13 08:35:52  System    -140000	my.isy.io
2020/04/13 08:36:27  System    -170001	[Network-DNS][Task=22] Failed DNS 190/rc=6
2020/04/13 08:36:27  System    -140000	my.isy.io
2020/04/13 08:37:02  System    -170001	[Network-DNS][Task=22] Failed DNS 191/rc=6
2020/04/13 08:37:02  System    -140000	my.isy.io
2020/04/13 08:37:37  System    -170001	[Network-DNS][Task=22] Failed DNS 192/rc=6
2020/04/13 08:37:37  System    -140000	my.isy.io
2020/04/13 08:38:12  System    -170001	[Network-DNS][Task=22] Failed DNS 193/rc=6
2020/04/13 08:38:12  System    -140000	my.isy.io
2020/04/13 08:38:47  System    -170001	[Network-DNS][Task=22] Failed DNS 194/rc=6
2020/04/13 08:38:47  System    -140000	my.isy.io
2020/04/13 08:39:22  System    -170001	[Network-DNS][Task=22] Failed DNS 195/rc=6
2020/04/13 08:39:22  System    -140000	my.isy.io
2020/04/13 08:39:57  System    -170001	[Network-DNS][Task=22] Failed DNS 196/rc=6
2020/04/13 08:39:57  System    -140000	my.isy.io
2020/04/13 08:40:32  System    -170001	[Network-DNS][Task=22] Failed DNS 197/rc=6
2020/04/13 08:40:32  System    -140000	my.isy.io
2020/04/13 08:41:07  System    -170001	[Network-DNS][Task=22] Failed DNS 198/rc=6
2020/04/13 08:41:07  System    -140000	my.isy.io
2020/04/13 08:41:42  System    -170001	[Network-DNS][Task=22] Failed DNS 199/rc=6
2020/04/13 08:41:42  System    -140000	my.isy.io
2020/04/13 08:42:17  System    -170001	[Network-DNS][Task=22] Failed DNS 200/rc=6
2020/04/13 08:42:17  System    -140000	my.isy.io
2020/04/13 08:42:52  System    -170001	[Network-DNS][Task=22] Failed DNS 201/rc=6
2020/04/13 08:42:52  System    -140000	my.isy.io
2020/04/13 08:43:27  System    -170001	[Network-DNS][Task=22] Failed DNS 202/rc=6
2020/04/13 08:43:27  System    -140000	my.isy.io
2020/04/13 08:44:02  System    -170001	[Network-DNS][Task=22] Failed DNS 203/rc=6
2020/04/13 08:44:02  System    -140000	my.isy.io
2020/04/13 08:44:37  System    -170001	[Network-DNS][Task=22] Failed DNS 204/rc=6
2020/04/13 08:44:37  System    -140000	my.isy.io
2020/04/13 08:45:12  System    -170001	[Network-DNS][Task=22] Failed DNS 205/rc=6
2020/04/13 08:45:12  System    -140000	my.isy.io
2020/04/13 08:45:47  System    -170001	[Network-DNS][Task=22] Failed DNS 206/rc=6
2020/04/13 08:45:47  System    -140000	my.isy.io
2020/04/13 08:46:22  System    -170001	[Network-DNS][Task=22] Failed DNS 207/rc=6
2020/04/13 08:46:22  System    -140000	my.isy.io
2020/04/13 08:46:57  System    -170001	[Network-DNS][Task=22] Failed DNS 208/rc=6
2020/04/13 08:46:57  System    -140000	my.isy.io
2020/04/13 08:47:32  System    -170001	[Network-DNS][Task=22] Failed DNS 209/rc=6
2020/04/13 08:47:32  System    -140000	my.isy.io
2020/04/13 08:48:07  System    -170001	[Network-DNS][Task=22] Failed DNS 210/rc=6
2020/04/13 08:48:07  System    -140000	my.isy.io
2020/04/13 08:48:42  System    -170001	[Network-DNS][Task=22] Failed DNS 211/rc=6
2020/04/13 08:48:42  System    -140000	my.isy.io
2020/04/13 08:49:17  System    -170001	[Network-DNS][Task=22] Failed DNS 212/rc=6
2020/04/13 08:49:17  System    -140000	my.isy.io
2020/04/13 08:49:52  System    -170001	[Network-DNS][Task=22] Failed DNS 213/rc=6
2020/04/13 08:49:52  System    -140000	my.isy.io
2020/04/13 08:50:27  System    -170001	[Network-DNS][Task=22] Failed DNS 214/rc=6
2020/04/13 08:50:27  System    -140000	my.isy.io
2020/04/13 08:51:01  System    -170001	[Network-DNS][Task=22] Failed DNS 215/rc=6
2020/04/13 08:51:01  System    -140000	my.isy.io
2020/04/13 08:51:36  System    -170001	[Network-DNS][Task=22] Failed DNS 216/rc=6
2020/04/13 08:51:36  System    -140000	my.isy.io
2020/04/13 08:52:11  System    -170001	[Network-DNS][Task=22] Failed DNS 217/rc=6
2020/04/13 08:52:11  System    -140000	my.isy.io
2020/04/13 08:52:46  System    -170001	[Network-DNS][Task=22] Failed DNS 218/rc=6
2020/04/13 08:52:46  System    -140000	my.isy.io
2020/04/13 08:53:21  System    -170001	[Network-DNS][Task=22] Failed DNS 219/rc=6
2020/04/13 08:53:21  System    -140000	my.isy.io
2020/04/13 08:53:56  System    -170001	[Network-DNS][Task=22] Failed DNS 220/rc=6
2020/04/13 08:53:56  System    -140000	my.isy.io
2020/04/13 08:54:30  System    -170001	[Network-DNS][Task=22] Failed DNS 221/rc=6
2020/04/13 08:54:30  System    -140000	my.isy.io
2020/04/13 08:55:05  System    -170001	[Network-DNS][Task=22] Failed DNS 222/rc=6
2020/04/13 08:55:05  System    -140000	my.isy.io
2020/04/13 08:55:40  System    -170001	[Network-DNS][Task=22] Failed DNS 223/rc=6
2020/04/13 08:55:40  System    -140000	my.isy.io
2020/04/13 08:56:15  System    -170001	[Network-DNS][Task=22] Failed DNS 224/rc=6
2020/04/13 08:56:15  System    -140000	my.isy.io
2020/04/13 08:56:50  System    -170001	[Network-DNS][Task=22] Failed DNS 225/rc=6
2020/04/13 08:56:50  System    -140000	my.isy.io
2020/04/13 08:57:25  System    -170001	[Network-DNS][Task=22] Failed DNS 226/rc=6
2020/04/13 08:57:25  System    -140000	my.isy.io
2020/04/13 08:58:00  System    -170001	[Network-DNS][Task=22] Failed DNS 227/rc=6
2020/04/13 08:58:00  System    -140000	my.isy.io
2020/04/13 08:58:35  System    -170001	[Network-DNS][Task=22] Failed DNS 228/rc=6
2020/04/13 08:58:35  System    -140000	my.isy.io
2020/04/13 08:59:10  System    -170001	[Network-DNS][Task=22] Failed DNS 229/rc=6
2020/04/13 08:59:10  System    -140000	my.isy.io
2020/04/13 08:59:45  System    -170001	[Network-DNS][Task=22] Failed DNS 230/rc=6
2020/04/13 08:59:45  System    -140000	my.isy.io
2020/04/13 09:00:20  System    -170001	[Network-DNS][Task=22] Failed DNS 231/rc=6
2020/04/13 09:00:20  System    -140000	my.isy.io
2020/04/13 09:00:55  System    -170001	[Network-DNS][Task=22] Failed DNS 232/rc=6
2020/04/13 09:00:55  System    -140000	my.isy.io
2020/04/13 09:01:30  System    -170001	[Network-DNS][Task=22] Failed DNS 233/rc=6
2020/04/13 09:01:30  System    -140000	my.isy.io
2020/04/13 09:02:05  System    -170001	[Network-DNS][Task=22] Failed DNS 234/rc=6
2020/04/13 09:02:05  System    -140000	my.isy.io
2020/04/13 09:02:40  System    -170001	[Network-DNS][Task=22] Failed DNS 235/rc=6
2020/04/13 09:02:40  System    -140000	my.isy.io
2020/04/13 09:03:15  System    -170001	[Network-DNS][Task=22] Failed DNS 236/rc=6
2020/04/13 09:03:15  System    -140000	my.isy.io
2020/04/13 09:03:50  System    -170001	[Network-DNS][Task=22] Failed DNS 237/rc=6
2020/04/13 09:03:50  System    -140000	my.isy.io
2020/04/13 09:04:25  System    -170001	[Network-DNS][Task=22] Failed DNS 238/rc=6
2020/04/13 09:04:25  System    -140000	my.isy.io
2020/04/13 09:05:00  System    -170001	[Network-DNS][Task=22] Failed DNS 239/rc=6
2020/04/13 09:05:00  System    -140000	my.isy.io
2020/04/13 09:05:35  System    -170001	[Network-DNS][Task=22] Failed DNS 240/rc=6
2020/04/13 09:05:35  System    -140000	my.isy.io
2020/04/13 09:06:10  System    -170001	[Network-DNS][Task=22] Failed DNS 241/rc=6
2020/04/13 09:06:10  System    -140000	my.isy.io
2020/04/13 09:06:45  System    -170001	[Network-DNS][Task=22] Failed DNS 242/rc=6
2020/04/13 09:06:45  System    -140000	my.isy.io
2020/04/13 09:07:20  System    -170001	[Network-DNS][Task=22] Failed DNS 243/rc=6
2020/04/13 09:07:20  System    -140000	my.isy.io
2020/04/13 09:07:55  System    -170001	[Network-DNS][Task=22] Failed DNS 244/rc=6
2020/04/13 09:07:55  System    -140000	my.isy.io
2020/04/13 09:08:30  System    -170001	[Network-DNS][Task=22] Failed DNS 245/rc=6
2020/04/13 09:08:30  System    -140000	my.isy.io
2020/04/13 09:09:05  System    -170001	[Network-DNS][Task=22] Failed DNS 246/rc=6
2020/04/13 09:09:05  System    -140000	my.isy.io
2020/04/13 09:09:41  System    -170001	[Network-DNS][Task=22] Failed DNS 247/rc=6
2020/04/13 09:09:41  System    -140000	my.isy.io
2020/04/13 09:10:16  System    -170001	[Network-DNS][Task=22] Failed DNS 248/rc=6
2020/04/13 09:10:16  System    -140000	my.isy.io
2020/04/13 09:10:51  System    -170001	[Network-DNS][Task=22] Failed DNS 249/rc=6
2020/04/13 09:10:51  System    -140000	my.isy.io
2020/04/13 09:11:26  System    -170001	[Network-DNS][Task=22] Failed DNS 250/rc=6
2020/04/13 09:11:26  System    -140000	my.isy.io
2020/04/13 09:12:01  System    -170001	[Network-DNS][Task=22] Failed DNS 251/rc=6
2020/04/13 09:12:01  System    -140000	my.isy.io
2020/04/13 09:12:36  System    -170001	[Network-DNS][Task=22] Failed DNS 252/rc=6
2020/04/13 09:12:36  System    -140000	my.isy.io
2020/04/13 09:13:11  System    -170001	[Network-DNS][Task=22] Failed DNS 253/rc=6
2020/04/13 09:13:11  System    -140000	my.isy.io
2020/04/13 09:13:46  System    -170001	[Network-DNS][Task=22] Failed DNS 254/rc=6
2020/04/13 09:13:46  System    -140000	my.isy.io
2020/04/13 09:14:21  System    -170001	[Network-DNS][Task=22] Failed DNS 255/rc=6
2020/04/13 09:14:21  System    -140000	my.isy.io
2020/04/13 09:14:56  System    -170001	[Network-DNS][Task=22] Failed DNS 256/rc=6
2020/04/13 09:14:56  System    -140000	my.isy.io
2020/04/13 09:15:31  System    -170001	[Network-DNS][Task=22] Failed DNS 257/rc=6
2020/04/13 09:15:31  System    -140000	my.isy.io
2020/04/13 09:16:06  System    -170001	[Network-DNS][Task=22] Failed DNS 258/rc=6
2020/04/13 09:16:06  System    -140000	my.isy.io
2020/04/13 09:16:41  System    -170001	[Network-DNS][Task=22] Failed DNS 259/rc=6
2020/04/13 09:16:41  System    -140000	my.isy.io
2020/04/13 09:17:16  System    -170001	[Network-DNS][Task=22] Failed DNS 260/rc=6
2020/04/13 09:17:16  System    -140000	my.isy.io
2020/04/13 09:17:51  System    -170001	[Network-DNS][Task=22] Failed DNS 261/rc=6
2020/04/13 09:17:51  System    -140000	my.isy.io
2020/04/13 09:18:26  System    -170001	[Network-DNS][Task=22] Failed DNS 262/rc=6
2020/04/13 09:18:26  System    -140000	my.isy.io
2020/04/13 09:19:01  System    -170001	[Network-DNS][Task=22] Failed DNS 263/rc=6
2020/04/13 09:19:01  System    -140000	my.isy.io
2020/04/13 09:19:36  System    -170001	[Network-DNS][Task=22] Failed DNS 264/rc=6
2020/04/13 09:19:36  System    -140000	my.isy.io
2020/04/13 09:20:11  System    -170001	[Network-DNS][Task=22] Failed DNS 265/rc=6
2020/04/13 09:20:11  System    -140000	my.isy.io
2020/04/13 09:20:46  System    -170001	[Network-DNS][Task=22] Failed DNS 266/rc=6
2020/04/13 09:20:46  System    -140000	my.isy.io
2020/04/13 09:21:21  System    -170001	[Network-DNS][Task=22] Failed DNS 267/rc=6
2020/04/13 09:21:21  System    -140000	my.isy.io
2020/04/13 09:21:56  System    -170001	[Network-DNS][Task=22] Failed DNS 268/rc=6
2020/04/13 09:21:56  System    -140000	my.isy.io
2020/04/13 09:22:31  System    -170001	[Network-DNS][Task=22] Failed DNS 269/rc=6
2020/04/13 09:22:31  System    -140000	my.isy.io
2020/04/13 09:23:06  System    -170001	[Network-DNS][Task=22] Failed DNS 270/rc=6
2020/04/13 09:23:06  System    -140000	my.isy.io
2020/04/13 09:23:41  System    -170001	[Network-DNS][Task=22] Failed DNS 271/rc=6
2020/04/13 09:23:41  System    -140000	my.isy.io
2020/04/13 09:24:16  System    -170001	[Network-DNS][Task=22] Failed DNS 272/rc=6
2020/04/13 09:24:16  System    -140000	my.isy.io
2020/04/13 09:24:51  System    -170001	[Network-DNS][Task=22] Failed DNS 273/rc=6
2020/04/13 09:24:51  System    -140000	my.isy.io
2020/04/13 09:25:26  System    -170001	[Network-DNS][Task=22] Failed DNS 274/rc=6
2020/04/13 09:25:26  System    -140000	my.isy.io
2020/04/13 09:26:01  System    -170001	[Network-DNS][Task=22] Failed DNS 275/rc=6
2020/04/13 09:26:01  System    -140000	my.isy.io
2020/04/13 09:26:36  System    -170001	[Network-DNS][Task=22] Failed DNS 276/rc=6
2020/04/13 09:26:36  System    -140000	my.isy.io
2020/04/13 09:27:11  System    -170001	[Network-DNS][Task=22] Failed DNS 277/rc=6
2020/04/13 09:27:11  System    -140000	my.isy.io
2020/04/13 09:27:46  System    -170001	[Network-DNS][Task=22] Failed DNS 278/rc=6
2020/04/13 09:27:46  System    -140000	my.isy.io
2020/04/13 09:28:20  System    -170001	[Network-DNS][Task=22] Failed DNS 279/rc=6
2020/04/13 09:28:20  System    -140000	my.isy.io
2020/04/13 09:28:55  System    -170001	[Network-DNS][Task=22] Failed DNS 280/rc=6
2020/04/13 09:28:55  System    -140000	my.isy.io
2020/04/13 09:29:30  System    -170001	[Network-DNS][Task=22] Failed DNS 281/rc=6
2020/04/13 09:29:30  System    -140000	my.isy.io
2020/04/13 09:30:05  System    -170001	[Network-DNS][Task=22] Failed DNS 282/rc=6
2020/04/13 09:30:05  System    -140000	my.isy.io
2020/04/13 09:30:40  System    -170001	[Network-DNS][Task=22] Failed DNS 283/rc=6
2020/04/13 09:30:40  System    -140000	my.isy.io
2020/04/13 09:31:15  System    -170001	[Network-DNS][Task=22] Failed DNS 284/rc=6
2020/04/13 09:31:15  System    -140000	my.isy.io
2020/04/13 09:31:50  System    -170001	[Network-DNS][Task=22] Failed DNS 285/rc=6
2020/04/13 09:31:50  System    -140000	my.isy.io
2020/04/13 09:32:25  System    -170001	[Network-DNS][Task=22] Failed DNS 286/rc=6
2020/04/13 09:32:25  System    -140000	my.isy.io
2020/04/13 09:33:00  System    -170001	[Network-DNS][Task=22] Failed DNS 287/rc=6
2020/04/13 09:33:00  System    -140000	my.isy.io
2020/04/13 09:33:35  System    -170001	[Network-DNS][Task=22] Failed DNS 288/rc=6
2020/04/13 09:33:35  System    -140000	my.isy.io
2020/04/13 09:34:10  System    -170001	[Network-DNS][Task=22] Failed DNS 289/rc=6
2020/04/13 09:34:10  System    -140000	my.isy.io
2020/04/13 09:34:45  System    -170001	[Network-DNS][Task=22] Failed DNS 290/rc=6
2020/04/13 09:34:45  System    -140000	my.isy.io
2020/04/13 09:35:20  System    -170001	[Network-DNS][Task=22] Failed DNS 291/rc=6
2020/04/13 09:35:20  System    -140000	my.isy.io
2020/04/13 09:35:55  System    -170001	[Network-DNS][Task=22] Failed DNS 292/rc=6
2020/04/13 09:35:55  System    -140000	my.isy.io
2020/04/13 09:36:30  System    -170001	[Network-DNS][Task=22] Failed DNS 293/rc=6
2020/04/13 09:36:30  System    -140000	my.isy.io
2020/04/13 09:37:05  System    -170001	[Network-DNS][Task=22] Failed DNS 294/rc=6
2020/04/13 09:37:05  System    -140000	my.isy.io
2020/04/13 09:37:40  System    -170001	[Network-DNS][Task=22] Failed DNS 295/rc=6
2020/04/13 09:37:40  System    -140000	my.isy.io
2020/04/13 09:38:15  System    -170001	[Network-DNS][Task=22] Failed DNS 296/rc=6
2020/04/13 09:38:15  System    -140000	my.isy.io
2020/04/13 09:38:50  System    -170001	[Network-DNS][Task=22] Failed DNS 297/rc=6
2020/04/13 09:38:50  System    -140000	my.isy.io
2020/04/13 09:39:25  System    -170001	[Network-DNS][Task=22] Failed DNS 298/rc=6
2020/04/13 09:39:25  System    -140000	my.isy.io
2020/04/13 09:40:00  System    -170001	[Network-DNS][Task=22] Failed DNS 299/rc=6
2020/04/13 09:40:00  System    -140000	my.isy.io
2020/04/13 09:40:35  System    -170001	[Network-DNS][Task=22] Failed DNS 300/rc=6
2020/04/13 09:40:35  System    -140000	my.isy.io
2020/04/13 09:41:10  System    -170001	[Network-DNS][Task=22] Failed DNS 301/rc=6
2020/04/13 09:41:10  System    -140000	my.isy.io
2020/04/13 09:41:45  System    -170001	[Network-DNS][Task=22] Failed DNS 302/rc=6
2020/04/13 09:41:45  System    -140000	my.isy.io
2020/04/13 09:42:20  System    -170001	[Network-DNS][Task=22] Failed DNS 303/rc=6
2020/04/13 09:42:20  System    -140000	my.isy.io
2020/04/13 09:42:55  System    -170001	[Network-DNS][Task=22] Failed DNS 304/rc=6
2020/04/13 09:42:55  System    -140000	my.isy.io
2020/04/13 09:43:30  System    -170001	[Network-DNS][Task=22] Failed DNS 305/rc=6
2020/04/13 09:43:30  System    -140000	my.isy.io
2020/04/13 09:44:05  System    -170001	[Network-DNS][Task=22] Failed DNS 306/rc=6
2020/04/13 09:44:05  System    -140000	my.isy.io
2020/04/13 09:44:40  System    -170001	[Network-DNS][Task=22] Failed DNS 307/rc=6
2020/04/13 09:44:40  System    -140000	my.isy.io
2020/04/13 09:45:15  System    -170001	[Network-DNS][Task=22] Failed DNS 308/rc=6
2020/04/13 09:45:15  System    -140000	my.isy.io
2020/04/13 09:45:50  System    -170001	[Network-DNS][Task=22] Failed DNS 309/rc=6
2020/04/13 09:45:50  System    -140000	my.isy.io
2020/04/13 09:46:25  System    -170001	[Network-DNS][Task=22] Failed DNS 310/rc=6
2020/04/13 09:46:25  System    -140000	my.isy.io
2020/04/13 09:47:00  System    -170001	[Network-DNS][Task=22] Failed DNS 311/rc=6
2020/04/13 09:47:00  System    -140000	my.isy.io
2020/04/13 09:47:35  System    -170001	[Network-DNS][Task=22] Failed DNS 312/rc=6
2020/04/13 09:47:35  System    -140000	my.isy.io
2020/04/13 09:48:10  System    -170001	[Network-DNS][Task=22] Failed DNS 313/rc=6
2020/04/13 09:48:10  System    -140000	my.isy.io
2020/04/13 09:48:45  System    -170001	[Network-DNS][Task=22] Failed DNS 314/rc=6
2020/04/13 09:48:45  System    -140000	my.isy.io
2020/04/13 09:49:20  System    -170001	[Network-DNS][Task=22] Failed DNS 315/rc=6
2020/04/13 09:49:20  System    -140000	my.isy.io
2020/04/13 09:49:56  System    -170001	[Network-DNS][Task=22] Failed DNS 316/rc=6
2020/04/13 09:49:56  System    -140000	my.isy.io
2020/04/13 09:50:31  System    -170001	[Network-DNS][Task=22] Failed DNS 317/rc=6
2020/04/13 09:50:31  System    -140000	my.isy.io
2020/04/13 09:51:06  System    -170001	[Network-DNS][Task=22] Failed DNS 318/rc=6
2020/04/13 09:51:06  System    -140000	my.isy.io
2020/04/13 09:51:41  System    -170001	[Network-DNS][Task=22] Failed DNS 319/rc=6
2020/04/13 09:51:41  System    -140000	my.isy.io
2020/04/13 09:52:16  System    -170001	[Network-DNS][Task=22] Failed DNS 320/rc=6
2020/04/13 09:52:16  System    -140000	my.isy.io
2020/04/13 09:52:51  System    -170001	[Network-DNS][Task=22] Failed DNS 321/rc=6
2020/04/13 09:52:51  System    -140000	my.isy.io
2020/04/13 09:53:26  System    -170001	[Network-DNS][Task=22] Failed DNS 322/rc=6
2020/04/13 09:53:26  System    -140000	my.isy.io
2020/04/13 09:54:01  System    -170001	[Network-DNS][Task=22] Failed DNS 323/rc=6
2020/04/13 09:54:01  System    -140000	my.isy.io
2020/04/13 09:54:36  System    -170001	[Network-DNS][Task=22] Failed DNS 324/rc=6
2020/04/13 09:54:36  System    -140000	my.isy.io
2020/04/13 09:55:11  System    -170001	[Network-DNS][Task=22] Failed DNS 325/rc=6
2020/04/13 09:55:11  System    -140000	my.isy.io
2020/04/13 09:55:46  System    -170001	[Network-DNS][Task=22] Failed DNS 326/rc=6
2020/04/13 09:55:46  System    -140000	my.isy.io
2020/04/13 09:56:21  System    -170001	[Network-DNS][Task=22] Failed DNS 327/rc=6
2020/04/13 09:56:21  System    -140000	my.isy.io
2020/04/13 09:56:56  System    -170001	[Network-DNS][Task=22] Failed DNS 328/rc=6
2020/04/13 09:56:56  System    -140000	my.isy.io
2020/04/13 09:57:31  System    -170001	[Network-DNS][Task=22] Failed DNS 329/rc=6
2020/04/13 09:57:31  System    -140000	my.isy.io
2020/04/13 09:58:06  System    -170001	[Network-DNS][Task=22] Failed DNS 330/rc=6
2020/04/13 09:58:06  System    -140000	my.isy.io
2020/04/13 09:58:41  System    -170001	[Network-DNS][Task=22] Failed DNS 331/rc=6
2020/04/13 09:58:41  System    -140000	my.isy.io
2020/04/13 09:59:16  System    -170001	[Network-DNS][Task=22] Failed DNS 332/rc=6
2020/04/13 09:59:16  System    -140000	my.isy.io
2020/04/13 09:59:51  System    -170001	[Network-DNS][Task=22] Failed DNS 333/rc=6
2020/04/13 09:59:51  System    -140000	my.isy.io
2020/04/13 10:00:26  System    -170001	[Network-DNS][Task=22] Failed DNS 334/rc=6
2020/04/13 10:00:26  System    -140000	my.isy.io
2020/04/13 10:01:01  System    -170001	[Network-DNS][Task=22] Failed DNS 335/rc=6
2020/04/13 10:01:01  System    -140000	my.isy.io
2020/04/13 10:02:23  System    -5	Start
1 minute ago, Michel Kohanim said:
Please do not use 8.8.8.8. Please use 8.8.4.4. But, it's always better to just let the router use whatever your ISP is providing as DNS.
My provider is Google so 8.8.8.8 and 8.8.4.4 is what they give me, I will just try the 8.8.4.4 and see what happens.
6 minutes ago, Michel Kohanim said:
@kccustom,
Please remove ALL port forwarding rules to ISY. Not just UDP.
I have removed all port forwarding rules and set the ISY to DHCP since I am not using any port forwarding I don't need the router to hand out a static ip do I? I am just now trying polyglot on a rpi3 but all the DNS trouble started way before that.
Lasted about and hour and did the same thing.
You don't happen to have an Ooma box or other VoIP,  do you?
I do have Ooma.
Just now, kccustom said:
I do have Ooma.
Where is it located? On the modem side of the Router or the LAN side of the router?
Everything is on the lan.  Fiber jack --> USG --> Switch. everything goes to the switch.  nothing goes through the Ooma.
Did you  turn off your Ooma DHCP server, and also  give yourself access via the Ooma WAN port? I moved my Ooma today from ISP side to LAN side and found out I had to turn off the DHCP server. It required a custom connection on another computer as it acts like it's own webpage and DHCP server. PITA to get it changed over because you can't access the settings from the usual access methods.
My fear was it could compete with the main router DHCP server and cause problems.  it shouldn't be a problem, but just a thought.
My Ooma is just plugged into the switch like it has been for years.
You could try disconnecting it temporarily.
I think I am going to go under the assumption that since nothing but my router has changed that that is where I need to be looking since the way everything was set up worked flawlessly for years.
