Voice command for relays "Turn on" vs "Open" command
I'm using the Insteon garage door controller to control my gate.  I currently have to ask google to "turn on the gate" to get it to open.  Is there a way add something or change that so i can ask google to "open the gate"?
You can set up a routine with "open the gate" then have it actually turn on the gate device.
Hope this helps,
Craig
Hope this helps,
Craig
I confirm that this works well with my curtains. Benoit recently added the "open/close" syntax for Alexa directly in ISY Portal, and hopefully same will come for GH.
  • 4 months later...
Second this. This will work nicely for blinds.
