Can't Access Alexa Skill
Alexa told me to re-enable skill this morning. Can't do so. I get the message that This Connection is Not Private. You Should Close This Page. Webbsite's certificate has expired. Certificate issued by Rapid SSL RSA CA has expired. Can I safely override this morning. If not, what must I do next?
Hopefully someone at UDI is monitoring this so that they can get the certificate updated...  This is the second issue with them in as many months.
5 minutes ago, ulrick65 said:
Same here.
Looks like we probably just need to wait until this gets resolved. I saw the option to override the warning but I don't plan to do that unless I can determine that can be done safely.
Edited by smokegrub
I wouldn't accept it.  I would wait until the certificate is updated.
Yea, I will wait for a response as well.  When I went to the Portal website I got the same error about the Certificate being invalid.  I went to it anyway and could not get anything to load in the Alexa Connectivity area.  I closed out and went back in and it now shows my devices and such, but still will not connect with Alexa.
I think it's on Amazon's side, at least mostly. I have a routine NOT tied to ISY (it's ALL Amazon) that is failing, too.
Interesting.  I know for a fact the Universal Devices site certificate is expired so I expected that to be it.  I mostly use the ISY as my main hub.  I also have an LG skill and I just tried it and it worked without issue.
yes, the SSL Cert expired this morning.  Tickets have been submitted.
I thought Alexa was ignoring me, but now I see why.
Me too.  Tracking certificate expiration is a common problem that we have at work all the time.
ALL -
It appears as though the certificate issue has been resolved.  Alexa integrations are working again, and the https://my.isy.io page no longer indicates an expired certificate.
Ok, we are back.....Thanks!
Thanks...good to go here as well.
