Recordkeeping Question?
Is there a way to extract the Insteon ID #'s, and the names I've given each switch from the ISY backup? Or is there a way to create the layout if you will of my network with out going into ISY. It would save some typing and time if I could just export the info into a spreadsheet.
aLf :?:
If your wanting to add to that document the remaining entries (ie. Is Load, Location, Notes) you have to enter them in the device properties.
To get to each device properties go to the Main tab, expand the tree to your ‘My Lighting’, right click on a device, and select properties. In this window you can add details to each device for the spreadsheet.
Hey Mark, thanks. But I was wondering if you could somehow extract the data from the backup-zip? I'm away from site and wanted to creat something--no internet connection yet unfortunately. aLf
Hello aLf,
Unforutnately, there's no way since the backup files are stored in binary.
I am so very sorry for the inconvenience,
aLf :?:
Michel:
Maybe you could give me a detailed explanation as to howw I could extract the info when (online) with ISY. If the list of devices is available through one of the pull-downs, maybe I could cut and paste from the excel sheet? Thanks.
Hello aLf,
It's quite simple: Tools->Generate Topology. This will create an HTML version with all of your configuration including the addresses, scenes, controller/responder relationships, notes, etc.
Please do let me know if this is not what you were looking for.
Michel:
