Polisy Disk Space
I recently had a storm roll through that knocked out power.  When my Polisy came back I could log into the web interface but nothing really worked.  After some troubleshooting it turns out the disk was 100% full, 0B free.  I ran a 'pkg clean' to free up enough space to get up and running again but is there a way to increase the disk size?  I don't really have much installed, just a couple of basic node servers and I'm pretty close to filling up the 5GB disk:
[admin@polisy ~]$ df -h
Filesystem           Size    Used   Avail Capacity  Mounted on
zudi/ROOT/default    5.0G    4.8G    217M    96%    /
devfs                1.0K    1.0K      0B   100%    /dev
procfs               4.0K    4.0K      0B   100%    /proc
zudi/tmp             217M     26K    217M     0%    /tmp
zudi/usr/home        221M    3.7M    217M     2%    /usr/home
zudi/var/crash       217M     23K    217M     0%    /var/crash
zudi/var/db          413M    196M    217M    47%    /var/db
zudi/var/db/pkg      224M    6.5M    217M     3%    /var/db/pkg
zudi/var/empty       217M     23K    217M     0%    /var/empty
zudi/var/log         218M    810K    217M     0%    /var/log
zudi/var/run         217M     48K    217M     0%    /var/run
zudi/var/tmp         217M     23K    217M     0%    /var/tmp
zudi                 217M     23K    217M     0%    /zudi
are there different sizes for polisy?
zudi/ROOT/default     25G    3.3G     21G    13%    /
zudi                  21G     23K     21G     0%    /zudi
zudi/tmp              21G     25K     21G     0%    /tmp
zudi/var/db           22G    306M     21G     1%    /var/db
zudi/usr/home         21G    350K     21G     0%    /usr/home
zudi/var/log          21G    320K     21G     0%    /var/log
zudi/var/run          21G     49K     21G     0%    /var/run
zudi/var/empty        21G     23K     21G     0%    /var/empty
zudi/var/crash        21G     23K     21G     0%    /var/crash
zudi/var/tmp          21G     23K     21G     0%    /var/tmp
zudi/var/db/pkg       21G    7.1M     21G     0%    /var/db/pkg
I believe all of them have 32GB mSATA SSDs.  However. the early batches had them formatted and partitioned down to 8GB.
There's a means to convert the file system to use the full 32GB -- open a support ticket with UDI.  (I had to do this on mine, but I'm not certain that the commands I used are current, and it's not worth risking -- best to check with UDI to get the correct sequence to fix this.)
