tmorse305 Posted August 11, 2020 Share Posted August 11, 2020 Hi @bpwwer, I just upgraded to 2.0.9 and I've lost my connection to my weatherflow station. Looking around this forum I saw that the Station must be the ID not the name. Is that a change as the configuration file had the name of my station saved. It used to work ok with this setting. I changed the station ID to 1866. Is this the ID it's looking for? Here is the log after the most recent restart. Thank you for your help. 2020-08-11 15:02:25,950 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2020-08-11 15:02:26,077 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.1.1', 'eth0')}, 2: [('192.168.1.1', 'eth0', True)]} 2020-08-11 15:02:26,077 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.1.1', 'eth0') 2020-08-11 15:02:26,078 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: eth0=[{'addr': '192.168.1.112', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}] 2020-08-11 15:02:26,078 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.1.112', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2020-08-11 15:02:26,079 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2020-08-11 15:02:26,131 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2020-08-11 15:02:26,132 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/5 - MID: 1 Result: 0 2020-08-11 15:02:26,133 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2020-08-11 15:02:26,134 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2020-08-11 15:02:26,138 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2020-08-11 15:02:26,141 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2020-08-11 15:02:26,190 NodeServer polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2020-08-11 15:02:26,190 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2020-08-11 15:02:26,191 NodeServer polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 30 2020-08-11 15:02:26,192 NodeServer polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2020-08-11 15:02:26,192 NodeServer polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2020-08-11 15:02:26,259 NodeServer polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 30 2020-08-11 15:02:26,332 NodeServer polyinterface ERROR weatherflow:query_wf: Bad: 'stations' 2020-08-11 15:02:26,333 NodeServer py.warnings WARNING warnings:_showwarnmsg: /home/pi/.polyglot/nodeservers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('192.168.1.112', 51994), raddr=('107.22.116.161', 80)> 2020-08-11 15:02:26,333 NodeServer py.warnings WARNING warnings:_showwarnmsg: /home/pi/.polyglot/nodeservers/WeatherFlowPoly/nodes/weatherflow.py:387: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('192.168.1.112', 51994), raddr=('107.22.116.161', 80)> 2020-08-11 15:02:29,346 NodeServer polyinterface ERROR hub:__init__: No sensor devices found (Sky, Air, Tempest) Link to comment Share on other sites More sharing options...
