September 13, 20206 yr Are there any guidelines as to how long one should wait before reading a device's data after querying the device? I'm trying to gather CURRENT data from Insteon Motion Sensor II, Light Level of 2476/7 switches, and Thermostat.
September 13, 20206 yr 22 minutes ago, shunsader said: Are there any guidelines as to how long one should wait before reading a device's data after querying the device? I'm trying to gather CURRENT data from Insteon Motion Sensor II, Light Level of 2476/7 switches, and Thermostat. If the MS II is battery powered, I don't think you're going to get current data, as I believe it only periodically updates to save battery. If it's powered by USB, then I suspect you can query it, wait a bit for the query to complete and be good to go, though I think the data should be current in the ISY, as the data is sent as it changes. Same for the switches and thermostat, though I don't have any Insteon thermostats. You can run a program to query a battery powered MS II upon motion detection, and it will update the values, such as this: MSIIQuery - [ID 00FF][Parent 00DF] If 'Devices / dirGarage / msGarage' is switched On Then Set 'Devices / dirGarage / msGarage' Query Else - No Actions - (To add one, press 'Action')
September 13, 20206 yr Author @Bumbershoot, is there a reason to query right after the motion detection? Perhaps because the device communications have been 'awakened'?
September 13, 20206 yr 6 minutes ago, shunsader said: @Bumbershoot, is there a reason to query right after the motion detection? Perhaps because the device communications have been 'awakened'? Yes.
September 13, 20206 yr 5 minutes ago, gzahar said: Yes. But what purpose is there to query when it just reported that it was switched On ? Edited September 13, 20206 yr by asbril
September 13, 20206 yr 14 minutes ago, asbril said: But what purpose is there to query when it just reported that it was switched On ? There is other data besides motion.
September 13, 20206 yr 1 minute ago, gzahar said: There is other data besides motion. I understand, but I would assume that once it sends status then it also sends the other data ?????
September 13, 20206 yr Author 18 minutes ago, asbril said: But what purpose is there to query when it just reported that it was switched On ? @asbrilI want the Luminance and Temperature values. I was hoping to be able to use these to determine whether I can open an East facing shade, or close during the winter.
September 13, 20206 yr Just now, shunsader said: @asbrilI want the Luminance and Temperature values. I was hoping to be able to use these to determine whether I can open an East facing shade, or close during the winter. My point/question is only that when the MS establishes communication and the AC registers that it is switched On, I would assume that at the same time it sends all data. If that is not the case, then I understand the need to query.
September 13, 20206 yr 2 minutes ago, asbril said: My point/question is only that when the MS establishes communication and the AC registers that it is switched On, I would assume that at the same time it sends all data. If that is not the case, then I understand the need to query. That is not the case.
September 13, 20206 yr Author @asbril, I'm noticing on my Console that data is stale, even though I've been tripping the outside motion sensors. Only when I use the "Query" button on the console do the numbers update. What's more is that there seems to be a hitch that I'm missing, because the data that I'm stuffing into the variables doesn't quite match the data that I see in the Level 3 Event data. Perhaps I need to upgrade to V 5.2.0. I upgraded last week from 4.8.0 to 5.0.14. I have a relatively large build in my home, and little time to fix things that don't go well during an upgrade.
September 13, 20206 yr Just now, shunsader said: @asbril, I'm noticing on my Console that data is stale, even though I've been tripping the outside motion sensors. Only when I use the "Query" button on the console do the numbers update. What's more is that there seems to be a hitch that I'm missing, because the data that I'm stuffing into the variables doesn't quite match the data that I see in the Level 3 Event data. Perhaps I need to upgrade to V 5.2.0. I upgraded last week from 4.8.0 to 5.0.14. I have a relatively large build in my home, and little time to fix things that don't go well during an upgrade. Understood. Some have issues with upgrade to 5.2, but I did not. However I had issues when going from 5.0.16 to 5.1, and then reverted back to 5.0.16, before finally going to 5.2 . It is important that you make backups before upgrading.
