"Run at Startup" won't stay set to ON
Here is the program:
       Repeat Every  15 minutes
          Set 'MasterBedroom-Thermostat' Query
I go to the program summary tab and right click on the program and turn "Run at startup" ON. Then I right click the program and click "Run (if)". The program continues to query the thermostat every fifteen minutes.
Then, a day or two later, I return to the console and the program is no longer set to Run at Startup and the program is no longer running.
Any ideas as to what is stopping the program from running and why the "run at startup" won't stay set to ON. (I'd also like to comment that I don't believe that my power has gone out at any time lately.)
thanks,
Someguy
Hi someguy,
Does your ISY actually reboot itself every one or two days? Otherwise, Run at startup would be meaningless.
In the meantime, we'll check into this issue.
thanks,
Someguy
In the program that 'someguy' posted, shouldn't it run forever once started? He reports that it has stopped, in addition to the "run at startup" status being turned off.
Here's another data point: I have three programs that should have "run at startup" enabled. I just noticed that none of the three currently have it enabled. Unfortunately, I have no idea when that happened. I am running 2.7.6.
I have a separate power supply connected to a UPS, so this isn't a huge issue for me. But I enabled the "run at startup" again for those three programs and will monitor more closely to see if they get cleared.
--Mark
I just checked and I have 2 programs set to run at startup, and they are still set to run and I rebooted sometime last week. So it appears mine is retaining the run at reboot. I also am on 2.7.6
Tim
Not sure why it's no longer set to 'Run At Startup'. What firmware version are you running?
Also - I believe you will need to put an IF condition in if you want it to start at reboot. Such as:
       From    12:00:00AM
       For      24 hours
How would I know if the ISY was rebooting itself. It has been doing some odd things lately: I've found my landscape lighting on during the daytime a couple of times.
Hi someguy,
thanks,
Someguy
Hi Michel,
I'm quite certain that this flag is not controlled by any other program action. I set it manually, and it should stay that way!
At the moment, all is still well. And, frankly, I don't expect to see any problems. I suspect that the flags got cleared in some fluke interaction while upgrading/rebooting/etc and will not easily be reproduced. But I wanted to mention it to add to collective data.
--Mark
Hi markens,
Apologies for a tardy reply ... we've been trying very hard to reproduce this problem to no avail. One question: are you sure you do NOT have any other programs that based on certain conditions turn this flag off?
