Fan speeds not working
Is everyone having problems setting fan speeds with Alexa? I have fanlinc controling my fans and I can no longer set speeds as a fan device or as a scene. I tried high med low and percentages but nothing seems to work anymore.
I'm on 5.1 for both. This was working fine before and I noticed my Alexa app updated recently so I thought they might have changed something. I did delete in Alexa and rediscover but it did not help. I will have to try deleting in the portal and rediscover but I don't know if I will have time today. I was just curious if others were having trouble because something was changed with an Alexa update. I will report back once I have a chance to mess with it.
Well I found some more time to test things further. I tried deleting the ISY V3 skill and adding it back. I deleted the fan devices and scenes and adding them back. I also tried a lighting scene and I could not adjust that at all either. Alexa only seems to be able to handle on and off for me anymore. If I try setting a scene to a % Alexa says it is not supported same as the speed for the fans added in the portal as a fan device.
Thanks but I can not upgrade to 5.3 I have the 300 zwave board. What version should people with the 300 board be using?
You need to use 5.0.16
Thanks for the help lilyoyo1 for what ever reason going back to 5.0.16C made it work again. I guess I will have to get the 500 board even though I was trying to avoid getting it for my small zwave use.
You're welcome. I'm glad you're back up and running
