How to Set Default Ramp Rate
Hi Everyone,
I'm in the process of building scenes for my insteon switches using the ISY -- is there a way to set the default ramp rate for scenes to 0.5 seconds (currently defaults everything to 0.1s), thereby avoiding having to manipulate this setting for each and every switch/controller combo?
No. You will need to configure each device separately. If you add the responders and configure them prior to adding the controllers, this will automatically update the controllers in that scene
