KPL LIghts
HI. Has anyone had an issue with KPL button lights going about 95% dim? They have worked ggod for a few years (old style KPL). The buttons still work, but the button lights are almost invisible. Is there a fix or will I be buying a new KPL?
Thanks, aLf
Hi aLf,
Have you used the Back Light settings on the Admin Console for your KPL?
Thanks, aLf
Hi Michel:
It is a really old KPL. I was under the impression that only the newer versions could dim? Is that right?
aLf
Any ideas? Trash the KPL?
aLf
Please save me the time in looking it up. I know you pull out the button, wait, then reset it and hold in. But then what do I do to ISY to get it back into the picture? What about the button functions, do they need to be re-programmed?
aLf
Hi aLf,
Yes:
1. Pull the set button out and leave it out for 10 seconds
2. Push it back in and keep in held in for 10 seconds
3. Right mouse click on it in ISY and choose Restore Device
Everything else should be programmed.
aLf
