Using "And" or "Or"
I'm new to ISY programming and was wondering if the following program will run correctly, or should I be using "And" in place of "Or"? Looking to create a "random look" On and Off of the device on Wed-Sat.
On Wed
From 6:25:00PM
To 6:44:00PM (same day)
Or On Thu
From 6:09:00PM
To 6:48:00PM (same day)
Or On Fri
From 6:02:00PM
To 6:35:00PM (same day)
Or On Sat
From 6:43:00PM
To 7:15:00PM (same day)
Set 'Foyer Key A (Lightpole)' On
Set 'Foyer Key A (Lightpole)' Off
Hi jfvalenti,
Why don't you use the Wait function with the Random attribute. It seems that the days are Wed, Thu, Fri, and Sat. So, make your condition as follows
On Wed
Time is 6:00:00PM
Or On Thu
Time is 6:00:00PM
Or On Fri
Time is 6:00:00PM
Or On Sat
Time is 6:00:00PM
Wait 0 hours 45 minutes 00 seconds Random
Do whatever needs to be done
So, the random will pick a number between 0 minutes (6:00 PM) up to 45 minutes (6:45 PM).
On Wed
From 6:25:00PM
Or On Thu
From 6:09:00PM
Or On Fri
From 6:02:00PM
Or On Sat
From 6:43:00PM
