Programs Error Not Implemented
Have just taken a 994iZW out of the box and set it up because the fabulous finder program can no longer find a working 99i.
Tech support on the 99i problem was a waste of an afternoon.
Have configured the new 994i and added a few programs.  On entering the programs|details tab an error gets thrown-  Not Implemented
Programs summary tab has-  Not Loaded and Out of Memory
This is for all programs including the factory Query that runs at 3 am.
A factory reset was done on the 994 and the SD card was removed and reinserted with not resulting change.
Java was updated to 8.271 and the previous version uninstalled.
994 was updated to 5.3.0
Java cache has been attempted to be cleared for an hour with multiple swings and misses as the UI stays at 4.*.*
If your
This does for sure sound like an old version of the admin console on the computer with new firmware in the ISY.
Follow the instructions in the first post of this thread to use The Launcher:
The launcher insures that your admin console version matches the firmware of the ISY.
OK.  Used link from Michel's forum entry Posted June 29, 2018 and downloaded another version of start.jnlp  It was stored as start(5).jnlp and the file downloaded 12 hours ago was start(4).jnlp
Start(4) must not have been used to open the admin console because copy 5 has the UI matching as it should and the Programs tab error is gone.
Now, having done a hard reset on the 994 the Query program has been wiped.  How important is this program from a stability and housekeeping standpoint.
Recreate it:
Query All - [ID 0002][Parent 0001]
        Time is  3:00:00AM
        Set 'ISY' Query
Factory Query Program
I would recommend always using the link that comes on the page with the firmware that you are downloading. That ensures you have the latest links.
