Zwave conversion question
I just received and installed the 500 series zwave controller and upgraded to 5.3. I'm currently converting everything I have to Zwave. I noticed when I add a simple GE zwave dimmer switch to the ISY it creates 3 separate devices. It adds the switch itself and then "Basic Scene Ctl 2 and basic scene Ctl 3". What is the purpose of these extra items? Do I need them or can I remove them from the ISY?
1 minute ago, lilyoyo1 said:
They can be removed. You'll see different nodes pop up from time to time that can be deleted
Thanks, but just curious what is their purpose?
Nothing. Zwave has a lot of underlying stuff built into that manufacturers of different devices can take advantage of. Most don't but it's still there.
As often happens, I learned something from @lilyoyo1 :-)  This being said, I put my "unknown" nodes in a separate folder for just in  case.
I'm not sure about GE, but for Homeseer dimmers the scene nodes are for detecting multitap up/down. Might be the same for GE.
There's no double tap features built into GE switches
