Problem with KPL when using local button
I created a scene with my KPL that contains a dimmer and the KPL .B button. When the scene is on, I want the dimmer to go to 60%. When the scene is off I want the dimmer to go to 0%.
When I test the scene in administrative console, all works well.
When I actually press the B button on the KPL, nothing happens, the administrative console doesn't even show that the KPL.B button is on (I see the light go on under the B button though)
Any clue as to the problem?
More details...
While my tree lists KPL, KPL.A, KPL.B, KPL.C and KPL.D, the status view says "Unsupported device: 1.27" I also note that the button will not add to the scene as a controller, only as a responder.
Hello again,
I have already responded to your trouble ticket.
In short, please upgrade your firmware to 2.7.6 or 2.7.7:
http://forum.universal-devices.com/viewforum.php?f=25
More details...
I had already upgraded, with no change, but then the next day I noticed that it was correctly recognized. I must have re-added it or something. Thank you for the responses.
