Can't add an Outlet linc
I had an electrical spike and one of my outlets died.  I've been trying to install an OutletLink Dimmer that I purchased several years ago.  Tried various ways to install it but keep getting the attached message.   Any idea what this means.
Are you manually typing in the address?  This happened to me and I had written down the address wrong... Took awhile to figure out that I was typing in the wrong address.
Good thouht...but I took a picture of it before I put the switch plate back on and it's good.   Wish it were that esay.
Yes, that did get the outlet installed.   However, have had multiple issues of it not working.   Plug a lamp in, with the little magnet, it buzzes and the red light flashes.
Unfortunately, I am leaving for 3 days and won't be able to play with this until I return.
Does the lamp have an incandescent or dimmable LED bulb?
The lamp you used should not have a built in dimmer switch,  high-low switch built in or low voltage bulb with a built in power supply.
