Need ISY Support for Insteon 2868-222 Siren
Just purchased two of these devices to add to my system and the ISY sees the address but tells me it is an unsupported device!
Now what???
Posted (edited)
Now what???
There are not supported in the 4.x branch or early 5.x of the firmware.  In current 5.x versions they are supported.
If you need to upgrade to v5.x and have a z-wave board, it's likely an older series 300 z-wave board that reports z-wave version 4.55.00, in that case install version 5.0.16C and don't go further until you upgrade your z-wave board.  If you don't have a z-wave board or have a series 500 board that reports version 6.81.00 then you can install the most current v5.3.3.  Please backup and read all the instructions before upgrading from version 4 to 5, some of your programs may need manual adjustments.
Z-wave upgrade link
Edited by MrBill
  • Like 1
37 minutes ago, joel.weisbrod@gmail.com said:
Can I go from 4.9 to 5.3?
36 minutes ago, joel.weisbrod@gmail.com said:
I have no ZWave
Here is the link to the upgrade post:
Make sure you read the notes section and the pre-requisites carefully:
Prerequisites:
  -  If your ISY version is currently 4.x.x then it must be version 4.6.2 or higher (upgrade if necessary) before upgrading to 5.3.2
  -  The latest release of Java must be installed
  -  If you are using MAC Yosemite and Java 1.8.40, please follow these instructions
Notes
-      Upgrading to this version may require a lot of manual intervention including verifying scenes, programs and program settings are correct.  In some cases it will be easier to rebuild your network.
Which version do I use and where can I download it? Both versions I found seem to have zwave support.
From the post provided above, item 3. Zwave support is only if you have the dongle.
  • Like 1
Posted (edited)
Upgrade to 5.3.3 went smoothly and I was able to add the siren to the system.
Now, most of my programs are listed as "Not Loaded" and "Out of Memory" and in yellow.
I tried to add a new program with on condition (if) and one action (then) and when I saved it it is yellow and also "Not Loaded" and "Out of Memory".
I have attached the about dialog as well.
I already did the fix for memory in the Java. I am unable to properly clear the Java cache for some reason (see attached).
Help!
Edited by joel.weisbrod@gmail.com
Help!
Your UI and Firmeware do not match and they should. Go back to the same upgrade page and download the ISY Launcher for v5.3.3. You should be using the Launcher to reach the admin console. You will need to clear your Java cache before running the Launcher.
Perfect!!!! Thanks so much to everyone for all your help and guidance!!! I am up and running at 100%
