Error Backing up ISY
When backing up my ISY, I now get this error (last few weeks):
Could not Retrieve File/CONF/UDFLPL.XML
Can someone point me to a solution?
I am trying to connect with Telnet without success.
Not sure if it is necessary with Telnet but I can't Enable Internet Access in ISY (Error: Failed Enabling Internet Access).
I have setup port forwarding on my eero router.
Both commands in Telnet "Telnet 192.168.1.80" and "Telnet 192.168.1.80 8150" give me an Invalid Command error.
Is there something I need to check/change?
RV
Telnet is not the Internet and no Internet access is needed.
Port forwarding is not needed and should not be enabled much, if at all. The IP addresses you are posting would not even work outside your LAN.
I forget the syntax for Telnetting (look it up on duckduckgo.com) but it is done from an open  command window on your PC or laptop.
https://www.lifewire.com/what-is-telnet-2626026
Thanks, Michel and Larry. All good now.
I was just not opening the connection in Telnet using the o command. Shame on me.
