UD Mobile error "No data found:Could not match Editor. PLEASE NOTIFY DEVELOPER"
When attempting to change any settings on a bulb controlled by the MagicHome node server, I am receiving a "No Data Found" pop up with the message "Could not match Editor. PLEASE NOTIFY DEVELOPER"
The devices respond correctly when manipulated through the ISY itself.
Sent from my Pixel 3 XL using Tapatalk
@Javi I made the edit in you pull request and can confirm that the problem no longer presents.@fahrer16 please accept the pull request.
@fahrer16 I just tried to update the node server through the dashboard and received the error "pull repo: undefined"
Thanks [mention]fahrer16 [/mention] I updated successfully and UD Mobile sync parse error is gone.
I have two LED strips. They are not automatically discovered so I hard coded them in node configuration which works great.
Today when I updated , I saw two parse errors in the log and I could not control LED strips. Realized both had gone offline to Wifi. Power cycled lights and restarted Polisy. The parse errors are gone and I can control lights. I’ll be fine from now on but might be good if parse error said can’t find the hard coded light set for first time users.
I realized that the update issue I had was due to my local changes. Fixed by:
sudo git reset --hard origin/master
and am now working correctly.
